Members Pintodeluxe Posted October 11, 2017 Members Report Posted October 11, 2017 Does anyone know a source for a small motor pulley that will fit a Rex 550w Servo? I recently installed Rex servos on a Consew 226 and a Consew 206RB-1, and the new motors came with 3" pulleys. As expected, they ran a little faster than I wanted so I went shopping for some smaller motor pulleys. Techsew sent me a 45mm O.D. pulley that they said would fit, but it had a 3/4" shaft. My Rex servos have a 5/8" shaft size. All of the 1-1/2" to 1-3/4" pulleys I can find have 3/4" bores. I did find 1-3/4" x 5/8" standard Chicago Pulleys at the hardware store, but they needed to have the set screw "knuckles" ground off before they would fit against the motor. These actually work pretty well, but it would be nice to have a source for a direct bolt-on part. Also, the Chicago pulley is a tad too wide for a 3/8" V belt. Another idea that came to mind is adding a bushing to make a 3/4" bore pulley fit the 5/8" shaft. Then you would have to cut a slot in the bushing to allow the woodruff key be inserted (or perhaps use a set screw instead). Any easy answers out there? I would love to find a 38mm O.D. pulley that fit a 5/8" shaft. Thanks so much. Quote
Members brmax Posted October 11, 2017 Members Report Posted October 11, 2017 (edited) You might try one of the dealers that sell that style. Some are on the site here in headings. Other than that if a thread tap tool is available this may help fix your correct width pulley predicament,locally. Good luck Floyd Edited October 11, 2017 by brmax Quote
Members andymanak Posted October 11, 2017 Members Report Posted October 11, 2017 A 5/8" to 3/4" split sleeve will be the easiest and cheapest, something like this should work: http://www.globalindustrial.com/p/motors/pulleys-sheaves/bushings/reducer-bushing-srb101220-galvanized-steel-58id-x-34od-114l?infoParam.campaignId=T9F&{lpurl}&vt-pti=B984124&gclid=CjwKCAjwgvfOBRB7EiwAeP7ehnb0-cdZ96n2w5V9kOuP0vGrbdcj-r3SScS39p_CG9oVjP_CYp52kBoCYlMQAvD_BwE Quote
Members DrmCa Posted October 11, 2017 Members Report Posted October 11, 2017 The torque on the pulley is not too big, you may be able to get away with a split bushing and no woodruff key Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members Gregg From Keystone Sewing Posted October 11, 2017 Members Report Posted October 11, 2017 5/8" bore pulley is very common for many new servo motors. Consew's clutch motor from I think the sixties and seventies made in Japan had this pulley bore. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Pintodeluxe Posted October 11, 2017 Author Members Report Posted October 11, 2017 Many good ideas here. Thanks for the link to the split sleeve Andy, that would be a quick fix. Grainger lists a 1-1/2" pulley with a 5/8" bore, but the picture is just a stock image of a 4" pulley so I'm not sure if it would work. Thanks again for all the helpful replies. Quote
Members DrmCa Posted October 11, 2017 Members Report Posted October 11, 2017 I find that Grainger is the kind of business where you get somewhere only with a walk in. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
CowboyBob Posted October 11, 2017 Report Posted October 11, 2017 (edited) You might want to double check your measurement it might be close to 5/8 which is 0.6250 & 15 mm is 0.5906 which is the diameter on most new servos.If there's a nut to hold the pulley on then it should be the 15mm. Edited October 11, 2017 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Pintodeluxe Posted October 11, 2017 Author Members Report Posted October 11, 2017 Okay I'll check with the calipers to see what the actual dimension is. Thanks Bob. Quote
Members Gregg From Keystone Sewing Posted October 11, 2017 Members Report Posted October 11, 2017 *I got 14.89mm, .0586", or .37/64" or 19/32" if you will. *Not exactly the 5/8" I was thinking of, I need to check my numbers again! Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
