Members JeannieH Posted November 14, 2017 Members Report Posted November 14, 2017 (edited) Hi. I am needing a raw edge binder attachment for my consew 227r cylinder machine. I've been looking on kwokhing.com. They have attachments for small cylinder and large cylinder machines. I'm assuming I have a large cylinder machine. I can't decide if I need the khf26 or khf8A. Is anyone familiar with these attachments? The khf26 is a suspended attachment. Will I need to change any parts like the presser feet? Also, is there an affordable provider for these in the United States? Thanks! Edited November 14, 2017 by JeannieH Quote
Members Constabulary Posted November 14, 2017 Members Report Posted November 14, 2017 Depends on how your machine is setup - (throat plate, feed dog, presser feet) Please post some pictures of your machine. I´m sure most sewing machine dealers can support you with binder attachments. F.I. check with Toledo Sewing Machines, OH or Keystome Sewing Machines, PA - both have a good reputation here and have a banner on top of this site Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members jimi Posted November 14, 2017 Members Report Posted November 14, 2017 Hi, i think your machine is a small cylinder arm machine. here is a picture of a 227r. Quote
Members JeannieH Posted November 14, 2017 Author Members Report Posted November 14, 2017 Ok so it's a small cylinder arm. I attached a pic of my machine. Jimi, where did you get your binder from? Quote
Members Constabulary Posted November 14, 2017 Members Report Posted November 14, 2017 seems your machine already is set up as a binder machine... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members brmax Posted November 14, 2017 Members Report Posted November 14, 2017 (edited) I think the first photo looks to have a plate designed already for an attachment. The diamond insignia may be known by others here. Its obvious a pro part. I would say though some binders can be a bit time consuming to install even though a benefit in usage. Something to really ask about in my oppinion. Good day Floyd ps: an excellent topic Edited November 14, 2017 by brmax Quote
Uwe Posted November 14, 2017 Report Posted November 14, 2017 (edited) Small and large are relative and depend on what you are actually referring to. On the KwokHing binder pages, they really mean large diameter vs. small diameter cylinder arms on machines. In that context, the Consew 227 and other vertical axis hook cylinder arm machines ( e.g. Singer 153W102, Juki 341, etc.) are considered large diameter, whereas most horizontal axis hook machines (e.g. Pfaff 335, Adler 69 etc.) are considered small diameter. I have a KHF48C 3/4" binder and the only machine it really fits is my Singer 153W102. I don't have a Consew 227 to test fit. The Consew 227 pictured earlier looks like it may only need a standard tape folder like the one shown below and a short inner binding foot to make it do binding work. Edited November 14, 2017 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members GPaudler Posted November 14, 2017 Members Report Posted November 14, 2017 Hi Jeannie, I'd also consider yours to be a large-cylinder machine. Keep in mind the thickness of the tape or ribbon or leather that you'll be using, the binder in Jimi's photo is what I'm used to using with thin, nylon ribbon and it wouldn't accept anything much thicker. The outer foot should be one-sided (only the left side) and the walking foot with the hole for the needle to pass through should be as short as possible. On my Pfaff 335 I've cut that foot off just behind the needle hole. You want to get the binder as close as possible to the needle without anything hitting. Feet as I've described will make it much easier for you to follow tight curves. Have fun, Gary Quote
Members JeannieH Posted November 14, 2017 Author Members Report Posted November 14, 2017 Thank you guys for all the feedback! Uwe, kwokhing doesn't have that type of folder listed for the large cylinder. Only for small. I will try surfing the web some more to see what's out there for me. I'm tired of messing up my pockets for my handbags. The hand skiving is already time consuming...can't afford a skiving machine so if I can make life a little easier with a binding attachment, I'm all for it! Quote
