Members gigi Posted January 18, 2018 Members Report Posted January 18, 2018 I was wondering what are the materials and what is the technique used to make something like this. Any ideas? (the example photos are from Pinterest) Thank you! Quote Houston, we have a problem
bikermutt07 Posted January 18, 2018 Report Posted January 18, 2018 I don't know, but I would like to find out. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members ENC Posted January 18, 2018 Members Report Posted January 18, 2018 I meet a lady selling masks like this at a street fair and asked if she was willing to share her basic methods. She said she soaked the leather in watered down white glue and then stretched and pinched the folds. It sounds like free hand wet forming with the glue as a stiffener when it drys. The leather looked like it was mostly embossed splits, under 3.5 -4 oz, and factory dyed. Ray Quote
mikesc Posted January 18, 2018 Report Posted January 18, 2018 (edited) The glue is PVA ( polyvinyl acetate )..or "wood glue"..or the sort of glue that you use in school..proportions are 10% to 15% in water..and then "play"..air dry , or you can accelerate the drying by using a hair dryer, but not too hot, and move it around, don't make "hot spots".( they'll crack )..Works best on thin veg tan, will also work on thin chrome tan, just not quite so well as on the thin veg tan..France has been full of this stuff for the last 50 years or so, ( mainly making "Tuareg heads", put a cheap face mask onto a"board, , put leather soaked in PVA solution over it, "smoosh", "squish", "pinch", "stretch" the leather around to make a "Tuareg" headdress effect..dry.. Voila!!... The countries on the other side of the "Med" from here made loads of "tourist souvenirs" based on this method..and it became a "craft technique "here..you can use the "technique" to make "deaths head" book covers or bags, or "whatever"..and you can mold over any object...The solution is "milky" but dries clear, but a little "shiny".. Knock yourselves out..:-)..only limit is your imagination..works on scrap pieces too, so you can build sculptures, pictures, flowers, masks, even armour*, whatever. * if armour is made this way as opposed to "Cuir bouilli".., don't get it wet, unless you also varnished it or waterproofed it in some other way..PVA when "set" is waterproof, but the leather treated this way is only "waterproof" ( actually it will be at best "water resistant" ) if it is totally saturated in the solution.. Edited January 18, 2018 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
bikermutt07 Posted January 18, 2018 Report Posted January 18, 2018 Thanks @mikesc. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members rodneywt1180b Posted January 18, 2018 Members Report Posted January 18, 2018 Thanks! I've seen pictures of it before and like the look. If the right project comes along it looks like it will be fun to try. Quote
Mjolnir Posted January 18, 2018 Report Posted January 18, 2018 (edited) I'm with mutt, I'd love to know. this is very thin. I think there are stretch marks on the tree limbs. I'm going to try out the glue. This was maybe stretched to the max over a form, form removed, then folded with a tool. maybe back filled to hold the shape? There are always several ways to get where you are going. Just saw mIkesc post. Awesome! Edited January 18, 2018 by Mjolnir ps Quote He attacked everything in life with a mix of extraordinary genius and naive incompetence, and it was often difficult to tell which was which. Douglas Adams
Members Matt S Posted January 18, 2018 Members Report Posted January 18, 2018 1 hour ago, mikesc said: ..."Tuareg heads"... Thanks Mike, my grandad had one of these on his wall when I was being dragged up. He told me how it was made and in my 7-year-old wisdom didn't believe him, but I never knew what to call it! Quote
mikesc Posted January 18, 2018 Report Posted January 18, 2018 (edited) Yes..you can "back fill" to help hold the shape..the "cheap and cheerful" way is to back fill" with sawdust mixed with the same wood glue( make a thick paste and fill all relief areas from the back until level )..if you are making lots of the same thing you make a mold ,"neg", of the shape you want to back fill, then you cast the shape and include it behind the leather prior to "smooshing"..some people use plaster to make the shapes, but you could use polyester resin ( it is lighter than plaster ) or even "papier maché, which is lighter again..You can make your "neg" molds from plaster, or silicone rubber, ( can be used very many times ) or just plasticine or sculptors clay ( can be used a few times if repaired between each time by placing it over a "pos" shape..When making molds in anything other than silicone ( or even latex if you are not allergic ) watch out for "undercuts" which make de-molding a PITA. Oh..and if you do use a mold..spray it lightly with cooking oil to make it easier to take the leather off, else it will stick, you are using glue after all and the flesh side of even chrome tan plus glue will stick to plaster..you can also wax the plaster a little first..as in rub with a white candle and heat with a hair drier to make the wax even..only a little wax will do ya, just want to make the "form" non absorbent. Edited January 18, 2018 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
mikesc Posted January 19, 2018 Report Posted January 19, 2018 Search "Tuareg leather masks" ( be warned, most of the images that google has for it on page one are badly done and ugly as crap ) or ( for more about "Tuareg" ) https://en.wikipedia.org/wiki/Tuareg_people Scroll down the page to see the image of a "Tuareg"..remind you of your Grandfathers wall ? :-) Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
