Members roderick Posted January 28, 2018 Members Report Posted January 28, 2018 Hi all, could anyone help me identify and troubleshoot this sewing machine. It has been dropped, taking someones knee out in the process, and the top arm of the frame cracked. It was welded and everything went back in place OK. It was working briefly about 20 years ago, then we moved and it got "stored" in the corner of the workshop. Have decided to resurrect it. First of all, any idea on the make and age? Secondly, I'm trying to get it to sew... it's timed well and the hook picks up the loop every time but the thread keeps catching on the opening in the bobbin case/hook where the tensioner is and won't complete a stitch. The hook just sits in there and rattles around, there is no clip or anything to hold it in. I'm wondering if there is something missing? If you don't out any tension on the needle thread it goes around the case and comes back up under the hook no problem. Say when picking up the bobbin the bobbin thread, but as soon as you try to sew and hang on to the thread ends to make the first stitch it catches on the case and won't slip around under the hook... Hope this makes some kind of sense... Thanks in advance... Rod ...Finland Quote
Members roderick Posted January 28, 2018 Author Members Report Posted January 28, 2018 photos didn't show? ...and hook/bobbin case Quote
Members roderick Posted January 28, 2018 Author Members Report Posted January 28, 2018 Sorry, how do I delete this thread?? Quote
Members Constabulary Posted January 28, 2018 Members Report Posted January 28, 2018 (edited) Coud be a Robert Kiehle, a Christian Mansfeld or a Heinrich Koch / Kochs Adler machine - Stand ist from Heinrich Koch / Kochs Adler so its likely the machine too. See some similarities? Its likely that I will not restore mine (not enough time and patience for this project) - mine is not sewing so I cannot help with adjustment but if you need parts or accessories from it .... Edited January 28, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members roderick Posted January 28, 2018 Author Members Report Posted January 28, 2018 Thank you, yes, looks very similar... I assume the table and the machine go together? Do you have the hook/bobbin case? I would like to see a photo of it when you have time. The other thread has the photos of my hook/bobbin case. It all went a bit wrong when I was trying to put up photos. Quote
Moderator Wizcrafts Posted January 28, 2018 Moderator Report Posted January 28, 2018 3 hours ago, roderick said: Thank you, yes, looks very similar... I assume the table and the machine go together? Do you have the hook/bobbin case? I would like to see a photo of it when you have time. The other thread has the photos of my hook/bobbin case. It all went a bit wrong when I was trying to put up photos. Oops, I deleted that post thinking it was pure duplication. Sorry. Can you re-post the photos showing the bobbin case and throat plate? That bobbin case has to have some kind of tab that sits inside a cutout in the throat plate. There would be some sideways clearance in that cutout, letting the bobbin case move slightly left and right, clearing the thread as it goes around the case. There might also be a lever that pulls the bobbin case backwards, forcing clearance as the thread just begins to go around the bobbin case. This part is nowadays called a latch opener. Recap: The bobbin case must not revolve. It should wiggle a bit to clear the top thread. The throat plate would likely have a cutout to hold the tab on the bobbin case, if one exists in the ancient machine. A lever would probably be used to pull back on the bobbin case as the thread makes its way around. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Northmount Posted January 28, 2018 Report Posted January 28, 2018 9 hours ago, roderick said: Sorry, how do I delete this thread?? For everyone's information, only moderators and up can delete posts and threads. You may report a post and explain what needs to be done to fix or delete it. Moderators are flagged when a report is made. We are keeping this thread. Tom Quote
CowboyBob Posted January 28, 2018 Report Posted January 28, 2018 5 hours ago, Wizcrafts said: Oops, I deleted that post thinking it was pure duplication. Sorry. Can you re-post the photos showing the bobbin case and throat plate? That bobbin case has to have some kind of tab that sits inside a cutout in the throat plate. There would be some sideways clearance in that cutout, letting the bobbin case move slightly left and right, clearing the thread as it goes around the case. There might also be a lever that pulls the bobbin case backwards, forcing clearance as the thread just begins to go around the bobbin case. This part is nowadays called a latch opener. Recap: The bobbin case must not revolve. It should wiggle a bit to clear the top thread. The throat plate would likely have a cutout to hold the tab on the bobbin case, if one exists in the ancient machine. A lever would probably be used to pull back on the bobbin case as the thread makes its way around. This machine looks like a Singer 34 & has the same type of shuttle that looks like a patcher only larger than the big bobbin 29.It has to spin for the machine to sew. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted January 29, 2018 Moderator Report Posted January 29, 2018 6 hours ago, CowboyBob said: This machine looks like a Singer 34 & has the same type of shuttle that looks like a patcher only larger than the big bobbin 29.It has to spin for the machine to sew. I guess I stand corrected. Sorry about my mistake. I have never seen a machine like that before. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members roderick Posted January 29, 2018 Author Members Report Posted January 29, 2018 Sorry, this took a while... no smart phones here! 23 hours ago, Northmount said: For everyone's information, only moderators and up can delete posts and threads. You may report a post and explain what needs to be done to fix or delete it. Moderators are flagged when a report is made. We are keeping this thread. Tom Thanks for the information Tom. I'll put the photos up first.... Quote
