Members superpacker Posted January 30, 2018 Members Report Posted January 30, 2018 First, let me say that I've read Hidepounder's excellent tutorial on burnishing - this has helped me to get uniform and smooth edges - but my question concerns dying the edge. A lot of newer leathermakers I see seem to leave burnished edges undyed - usually because the item itself is made from a light colored veg tan of some sort and is intended to darken with use and age. Even so, I like the look of dyed edges. I think if looks more finished, and adds nice contrast, even if the leather darkens. However, I'm having trouble keeping the dye on the edge. For example, I recently worked on a natural tooling leather belt. I intended it for a work belt that would darken with use, but wanted to add a medium/dark brown contrasting edge. Completed all the steps of making, burnished, and only had to dye the edge. I used Fiebings Medium Brown spirit dye, and a wool dauber, and despite my best care, the dye soaked over the edge and on to the belt front. So I'm trying to figure out how to keep dye only on the edge when the only thing that will be dyed is the edge. Any thoughts? The same goes for dyed leather too, where I frequently like to use a black edge Quote
Members cradom Posted January 30, 2018 Members Report Posted January 30, 2018 Dye your edge before burnishing. When you burnish you make it much harder for dye to soak into the leather, therefore it drips down the front (or back) and ruins things. Painting edges is different. You're using a paint which sticks to the leather rather than soaking in. Quote
Members Mattsbagger Posted January 30, 2018 Members Report Posted January 30, 2018 I dye after I burnish. The edge is harder and doesn't soak in as fast. I use a small dauber burned down to not much bigger than a Q Tip. Go slow and easy. Quote
Members superpacker Posted January 30, 2018 Author Members Report Posted January 30, 2018 Do you try to do it in one continuous stroke? It seems, at least like with lighter dyes like medium brown, if you do it in pieces you get overlapped darker areas. Quote
Members Dunluce Posted January 30, 2018 Members Report Posted January 30, 2018 I recently read of someone using Molotow markers to apply due to their edges. These are markers that can be filled with your own dye and have different size tips that can be used. I have been looking at getting some tomtrial myself https://shop.molotow.com/en/marker-refills/molotow-leermarker-411em.html?___from_store=de Quote
terrymac Posted January 30, 2018 Report Posted January 30, 2018 (edited) Get hold of Bob Park (Hidepounder). He is handling some edge markers that you put your own dye, and he is also handling a product called Edge Magic that you treat the edges with before burnish. You can contact him at Hidepounder@gmail.com Hope this helps, Terry Edited January 31, 2018 by Northmount Corrected name Quote
Members YinTx Posted January 31, 2018 Members Report Posted January 31, 2018 @gmace99 put out a tutorial/video on using a piece of felt tied around the end of a stick, left in the jar after you use it. I tried this method, and it works well and is cost effective. However, I used a soft piece of felt, and I think it would be much more effective with a hard piece of felt. Less is more here if you don't want bleeding to the front side. I have found that burnishing a lightly dyed edge will result in a dark edge, which I like as well. I just bought a dye pen that you fill on your own, and look forward to giving it a try as well. YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Contributing Member LatigoAmigo Posted January 31, 2018 Contributing Member Report Posted January 31, 2018 FYI: Here is Bob Park's product flyer. Parkway Products Flyer.pdf Quote
Members AndersenLeather Posted January 31, 2018 Members Report Posted January 31, 2018 This is one way to do it: andersenleather.blogspot.com/2015/10/burnish.html The trick is to burnish the very edge of the edge before dyeing the edge. I also use a felt marker. A wool dauber should only be used if the edge is the same color as the leather. Quote
terryHHI Posted January 31, 2018 Report Posted January 31, 2018 I use Bob Park’s Edge Markers and love them. Easy to control how much and where edge dye goes. I keep the tips fairly dry so dye isn’t soaking into unwanted areas. Quote
Members Dunluce Posted January 31, 2018 Members Report Posted January 31, 2018 4 hours ago, jonasbo said: This is one way to do it: andersenleather.blogspot.com/2015/10/burnish.html The trick is to burnish the very edge of the edge before dyeing the edge. I also use a felt marker. A wool dauber should only be used if the edge is the same color as the leather. When you mentioned this I remembered that is where I saw the molotow markers being used http://andersenleather.blogspot.co.uk/2015/10/burnish.html i believe he also uses larger ones elsewhere for dying larger areas of leather. He does some quality work. Quote
