Members Instinctive Posted February 2, 2018 Members Report Posted February 2, 2018 The manual for a recently acquired Singer 112W139 call for 126x9 needles which I understand are no longer available. I am told that other models of 112W will take #135x17 needles. Will these work in the 112W139 or what do I need to do to get needles i this thing. Thanks. Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Uwe Posted February 3, 2018 Report Posted February 3, 2018 I'd try some 126x3 needles, which apparently are the same as 126x9, according to this Groz-Beckert needle pack: The 126x3 needles are available online: http://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Category_Code=NDL-126x3 Our trusty banner vendors may carry them, too. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Instinctive Posted February 3, 2018 Author Members Report Posted February 3, 2018 2 hours ago, Uwe said: I'd try some 126x3 needles, which apparently are the same as 126x9, according to this Groz-Beckert needle pack: Thanks for this. New to machine sewing. I wonder how the round needle does in leather? Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Members Constabulary Posted February 3, 2018 Members Report Posted February 3, 2018 (edited) I would check if you probably already have other machines using f.i. 135x17 needles and then setup this and all other machines with the same needle system. Advantage is you only have to stock 1 needle system and you can use the same needle in all your machines - IF the 135x17 needle works in your other machines. When ever possible I setup may machines to 135x17 - my Pfaff 345, Singer 212G and Singer 34K which originally used a different needle system, are setup with 135x17. 135x16 is the leather needle other than the tip its the same as the 135x17 needle. Edited February 3, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Instinctive Posted February 3, 2018 Author Members Report Posted February 3, 2018 9 hours ago, Constabulary said: I would check if you probably already have other machines using f.i. 135x17 needles and then setup this and all other machines with the same needle system. Advantage is you only have to stock 1 needle system and you can use the same needle in all your machines - IF the 135x17 needle works in your other machines. When ever possible I setup may machines to 135x17 - my Pfaff 345, Singer 212G and Singer 34K which originally used a different needle system, are setup with 135x17. 135x16 is the leather needle other than the tip its the same as the 135x17 needle. Thank you for this. You advice got me thinking. The machine came from the estate of machine repair guy. I took a needle out. It's a Muva 120 with a 1.95 mm shank so i'm thinking it's all ready been converted. I found this little chart that compares needle sizes http://ismacs.net/needle_and_shank/needle-cross-reference-chart-round-shank.html. The 135x17 has a 2 mm shank and is exactly the same length as the Muva 120 that I have measured. Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
Members Constabulary Posted February 3, 2018 Members Report Posted February 3, 2018 so it depends on the needle hole in the needle bar - maybe it can accommodate the 135x17 Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Hockeymender Posted October 31, 2020 Report Posted October 31, 2020 Gunna revive an old topic. My 112W-139 states it uses 135x17 needles, as can be seen in the pic. I ordered 135x17 and to my disgust the needles will not fit into the needle bar. Checked into the 126x3 mentioned above and it appears they are only available in 110. Was hoping for at least 120 (using 69 thread). Any ideas? Quote Regards, Joe Esposito www.hockeymenders.com instragram: @hockeymenders.com
Members Constabulary Posted November 1, 2020 Members Report Posted November 1, 2020 You probably can replace the needle holder if not frozen or is one piece with NB ex factory. I´m not sure in your case but the new NB have replaceable needle holder. If not replaceable buy a new gauge set with needle bar. I´m pretty sure the nowadays needle holder will take 135x17 needles but better check with the dealers. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members sandmanred Posted November 1, 2020 Members Report Posted November 1, 2020 To your question about round needles in leather, maybe okay if it's soft leather but if its hard leather probably not so well. The leather needles I've seen have a wedge or chisel shape that cuts through tough leather. I just tried a round point vs a leather on some veg tan leather that is about 3/16 inch thick. The round needle took a lot more force to punch through and then actually pulled out of the needle bar on the very first up stroke. The leather needle punched right through and sewed without a problem. Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
Members ke6cvh Posted November 16, 2020 Members Report Posted November 16, 2020 We have a 112w-140 and 139. I tried to convert the needle bar from a generic kit off that famous auction site and shipped from China and the kit did not fit on the 139. We were able to put dbx1 in the machine with existing/stock needle bar and adjust the needlebar height. If I remember correctly 135x17 was our first "want" but the shank was too big (although I may be getting mixed up with our 140 but don't think so....I do know we ended up using dbx1 in one of the machines because the smaller shank diameter. dbx1 is available in a large assortment of tips including leather points from a quick google search. Best regards, Mike Quote
