What a bunch of beauties....
Gorgeous
Fine fine work!
One day at a time my friends
              John
17 hours ago, blue62 said:
What do you use for dye and top coat?
Thanks,
John
Some of those are drum dyed mahogany skirting from Wickett and Craig. I used Fiebing's dyes and acrylic resoline for some.
Outstanding! I really like your sight channel bump out! Classy looking holsters for sure and great attention to detail in the assembly and finish.
Thanks for sharing!
Very nice work!! Excellent edge finishing, dyeing, stitching and wet-forming. High quality leather.
Are you using vacuum forming?
Edited by gigi
Houston, we have a problem
do you skive the leather at all from it's skirting weight to the working weight of the leather?  And if so about what is the working weight of the leather while using it.  Also what product do you use to clean the leather prior to the final coat finish?
thanks for all the info!
Thanks for sharing!
Thanks Josh!
Thank you. No vacuum, hand molded.
All leather is ordered as 7/8, most recently directly from Wickett and Craig. Other than me wet molding it, nothing to clean it. Once dried, finish coat is applied.Well, I do buff before applying finish.
Edited by IngleGunLeather
Update
Thanks for your response and as others have said very nice work very nice indeed!!
Perdy
If you can live, thank god
If you can read, thank a teacher
If you can read this in English, thank a veteran
May God Bless,
Carson of C Hangin Diamond Leather and Catte Company
Super clean work and look from the molding to the stitching... inspiring actually.
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
5 hours ago, MedusaOblongata said:
Great looking holsters!
How is the bottom closed? Is it one piece of leather folded in half at the muzzle?
The bottoms aren't fully closed. The leather, both front and back pieces, are approximately 1/4 inch longer than the muzzle and are slightly folded over.
