2 hours ago, Stetson912 said:
I know immiketoo would say cut less bevel more, meaning cutting lightly with a swivel knofe or not at all. so i would give it a try both ways (cutting light and heavy) and see which gives the best results.
I would say that :)  Maybe I should say cut correctly bevel the right amount?  There are infinite combinations of this that will work, as long as you find what works for you.
Learnleather.com
Is this bevelling possibly done from both side of the leather? As in, bevelled the top side and also bevelled the back, then the back filled with ... something ... wax? Epoxy? Wadding?
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
8-10 oz Wickett & Craig leather. Properly cased and beveled with a Tandy B803. Only tooled on the top.
I always cut in my line with 1/4 in swivel blade. For that technique I prefer the Square cut one and not the 45 angle for this as I can cut lines a bit straighter and get more blade in for a bit more exaggerated width.
I have two smooth store bought bevelers, a b200 and a b935. The B935 is thinner but much steeper than the b 200.
With my cut made I put my beveler in the cut and draw. If you want more just go back to the top of your line and draw again until you are happy. I get nice clean bevels with this method.
I also made a tool from some brass rod that will bevel both sides of the cut. Same deal .. but a nice cut, fairly deep is needed to hold the tool. Then I just press and push until I am happy.
  • 2 weeks later...
Absolutely beautiful @JRLeather2 Absolutely beautiful...
I think of Chinese food when I think of life;
That's sweet and sour.
My life is sweet as saccharin.
Ye Scurvy Dog.   Swords, Weapons, Dungeon Furniture, Custom Leather Work, and More...
Beveling can be a challenge getting the casing just right sure helps.
    JRLeather2,  WOW! beautiful beveling!
Handmade doesn't have flaws it's just built-in character.
Excellent job. I can only hope to be this good.
Kindest regards
Brian
Thanks for the kind words. I should also point out that was done with no swivel knife cuts and a single pass with the beveler. I also lean the beveler back to get the other line.
  • 2 years later...
I just came across this post wow searching for bevelers. This is as good as it gets, folks. Excellent work JL.
