Members 3248tm Posted May 19, 2018 Members Report Posted May 19, 2018 (edited) Still at it and learning as I go. Top one is a 4.5 inch coaster. It has pigskin on bottom side amd it worked out great. the dye and clear coat was a wreck to say the least. Still have some spacing issues I want to work on and then get my bead lines looking better and some other stuff The two holsters are my cut out pattern and i keep making small changes to the pattern every time but I think that it is getting very close to what I want on this type of holster. They are similar to a cowboy fast draw type pattern. I learn a few things every time I make one so hopefully the next one looks even better. The edges on the fold over holster were not finished up in this photo . Any comments would be great. Edited May 19, 2018 by 3248tm Add more info Quote
bikermutt07 Posted May 19, 2018 Report Posted May 19, 2018 Keep it up, it's all looking good. Din Gonzales has a really good video on antiqueing leather. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members koreric75 Posted May 19, 2018 Members Report Posted May 19, 2018 Those look great, I had a rough time with the antique and top finish as well, o started doing the antiquing in the same manner as before, put it on and take off the raised areas with a stiff piece of leather with a paper towel wrapped around it (more like scraping it off the top), let it dry then spray my top finish on, let dry good then buff...I really like the way you got the spacing on the coaster where the corners end up leaving a spade shape. Quote Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
Members noobleather Posted May 20, 2018 Members Report Posted May 20, 2018 Great looking work on those holsters.Want to do a full rig for my single action gear one day.Keep at it Quote
Members Handstitched Posted May 26, 2018 Members Report Posted May 26, 2018 G'Day, No complaints here, they look beautiful . Antiquing was a challenge for me once upon a time, but now I have the hang of it. I've by no means mastered it,I still make ' mistooks' , but my antiqued projects looks so much nicer these days, thanks to a bit of info I got from this site I have a bag full of my little sample pieces like you have there. One day I'll mount them all in an album of some kind for advertising & showing off purposes . but well done on those. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
