Members plinkercases Posted June 16, 2018 Members Report Posted June 16, 2018 in researching I see the term hand wheel and balancing wheel and it seems they are almost interchangeable....but if I was to change the "wheel" on my machine to a larger one to make hand rotating easier I have a few questions: is the solid wheel weight a necessity as a flywheel effect on the machines operation? if the wheel and head pulley were both replaced with a larger/lighter pulley to make hand crank and reduction all in one.... will the loss of wheel mass affect machine operation? where can one get larger diameter solid hand/balancing wheels to replace the smaller one with? I have tried all kinds of searches. Machine is a Pfaff 335 as some may have guessed Thanks in advance. Quote "Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691 plinkercases.ca
Northmount Posted June 17, 2018 Report Posted June 17, 2018 Heavy hand wheels were used on treadle machines to take advantage of the inertia of a flywheel and carry the machine past the top and bottom dead centres of the pitman. Unless you are going to wheel the machine quickly by hand, and expect it to make a full revolution or two, there will be no advantage of using a heavy wheel/pulley. If you can find a treadle operated machine, you should take the opportunity to sit down and play with it for a while. New experience. Tom Quote
Members Gregg From Keystone Sewing Posted June 18, 2018 Members Report Posted June 18, 2018 (edited) I've seen handwheel, balance wheel, and pulley all being used for the same thing. The only technical term that can be a variance is handwheel vs a balance wheel. The balance wheel has a counter weight or material cut away to prevent the machine from bouncing as it operates where a hand wheel does not. Other than that, I'm sure there are some more technical specific terms used out there for this stuff. In my world, if you can differentiate between the machine hand wheel and the motor drive pulley, we're good. Edited June 18, 2018 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members dikman Posted June 18, 2018 Members Report Posted June 18, 2018 As Gregg has mentioned, if the machine is being used at high speed then a balance wheel is just that, designed to ensure that nothing is out of balance while spinning. If you're using a servo and running at low speeds then balance is pretty much a non-issue, so any handwheel or pulley that will fit should be fine. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Moderator Wizcrafts Posted June 19, 2018 Moderator Report Posted June 19, 2018 I have owned two Union Lockstitch machines. The driving wheel on the back weighs about 50 pounds. I called it a flywheel. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
