Members Railrider1920 Posted June 23, 2018 Members Report Posted June 23, 2018 Hi folks, I've been watching a few carving videos here lately, trying to learn a little. Are there any particular youtube channels geared toward the beginner you would suggest I check out? Thanks, Rob Quote
Moderator immiketoo Posted June 23, 2018 Moderator Report Posted June 23, 2018 Ian Atkinson has a ton of good content. He is Leodis Leather on youtube. My site also has a lot of good stuff, www.learnleather.com. Quote Learnleather.com
Contributing Member JLSleather Posted June 23, 2018 Contributing Member Report Posted June 23, 2018 That's going to depend on what it is you're wanting to do. There are some videos some will find helpful. BUT you've probably already noticed how many "leather videos" and "how-to" are just an ad for the guy in the video (sometimes by "experts" who clearly have no idea what they are doing). To begin, I suggest you identify the type of work you are wanting to do. I recommend checking out http://www.leathercraftlibrary.com/default.aspx? and https://www.youtube.com/user/TandyLeatherFactory/videos Some of that will be helpful to you, and some may not. Either way, it should give you an idea of the direction you want to go. Beyond that, I try to answer questions as honestly as possible. Videos CAN be useful, but pay attention to the CONTENT. One clear example -- I use the restroom every day. I could make a video, in high-def and 1080p , and add some background music, maybe pay a "celebrity' to tell you how great the video is going to be for you. In the end, it's still the same thing. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Northmount Posted June 23, 2018 Report Posted June 23, 2018 4 minutes ago, JLSleather said: sometimes by "experts" Definition: X is an unknown quantity, spurt is a drip under pressure. Tom Quote
Members Raksha Posted June 23, 2018 Members Report Posted June 23, 2018 Tandys, learnleather.com and armitageleather are the ones I have found most usefull. Seen a lot of videos of people making nice stuff, but not really learning anything usefull becaus the just do it, and do not explain in a way that gives me anything. Mind, english is not my native language so I need them to talk clearly and not much background music. Quote
Members Raksha Posted June 23, 2018 Members Report Posted June 23, 2018 Have to mention weaver leathercraft and leodis leather too. Quote
Members Railrider1920 Posted June 23, 2018 Author Members Report Posted June 23, 2018 Tom, you're quite right. JSLeather, thanks for the links, I'll check them out asap. Being honest is best. So far I've ruled out a couple "experts". No thanks on the bathroom videos, but if you pay me enough, I'll do the voice over lol. I am looking to do carving, but not the traditional western. I like the celtic/viking work Dark Horse Workshop does. Also things like the Iron Maiden "Eddie" mask immmiketoo did. But, have to start with something basic, probably flowers since most carvers could tell me what I'm doing right or wrong with those. Mike, I just watched a couple of your videos. Cut less, bevel more was the last one. What is the tool you use, I think you called it a swivel beveler. It looks a little like an aluminum knitting needle with a flattened end (but doesn't actually swivel). I also found Ian Atkinsons vids. Just watched one of those as well. Thanks for doing the videos. Raksha, thanks for the names. I'll look them up. Quote
Moderator immiketoo Posted June 23, 2018 Moderator Report Posted June 23, 2018 4 minutes ago, Railrider1920 said: Tom, you're quite right. JSLeather, thanks for the links, I'll check them out asap. Being honest is best. So far I've ruled out a couple "experts". No thanks on the bathroom videos, but if you pay me enough, I'll do the voice over lol. I am looking to do carving, but not the traditional western. I like the celtic/viking work Dark Horse Workshop does. Also things like the Iron Maiden "Eddie" mask immmiketoo did. But, have to start with something basic, probably flowers since most carvers could tell me what I'm doing right or wrong with those. Mike, I just watched a couple of your videos. Cut less, bevel more was the last one. What is the tool you use, I think you called it a swivel beveler. It looks a little like an aluminum knitting needle with a flattened end (but doesn't actually swivel). I also found Ian Atkinsons vids. Just watched one of those as well. Thanks for doing the videos. Raksha, thanks for the names. I'll look them up. Railrider, Thank you. In the video, I am using a steep figure beveler by Bob Beard. Its the only tool I've found with the right shape for this technique, although there may be others that can do the trick, or you may be able to modify your own to suit your style. I use B2 through B6. If you want to see a close up, let me know. Now, for figure carving, this is the single most useful technique I have, and now you have it too. You can use it to do 80% of your figure carving, and after that, the rest is easy. A little matting and some spoon work and you're well on your way to figure carving mastery. Also, there is NO reason to start with floral carving if you don't want to do floral carving. The techniques have some overlap, but generally, if you can carve a face, you can carve a flower. The converse isn't necessarily true as the beveling techniques are vastly different. Regarding the Eddie or any of the other faces I have done, its all the same as what in my video. This one has both celtic and figure carving with Odin and his crows. Celtic is a pain, but a few simple tips can help. Number one, always cut just outside your lines on knot work so you can see where you're going. Always maintain the same thickness on knot work or it looks bad. On intersections, how you bevel makes all the difference, and a standard steep beveler isn't enough. You will want a figure or shallower beveler to create the appearance of over under on you weave. If you're interested, I can put together a short segment on Celtic carving for you since it's not too complicated, you just need to follow the formula and pay attention to the details. Quote Learnleather.com
Moderator Johanna Posted June 23, 2018 Moderator Report Posted June 23, 2018 Learnleather.com is the most convenient source of videos for serious leatherworkers. If you attend the class you can ask questions in real time, but either way, you can watch the video, start, rewind and pause, over and over again. The teachers are masters of their style and they patiently guide you through whatever the lesson is. If you don't see what you're interested in, ask. They will find a pro and set up a class. Most leatherworkers are willing to share their ideas and techniques because they know no one can steal their imaginations, which the lack of is the only thing that will ever limit your progress. Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Members Raksha Posted June 23, 2018 Members Report Posted June 23, 2018 1 hour ago, immiketoo said: Thank you. In the video, I am using a steep figure beveler by Bob Beard. Its the only tool I've found with the right shape for this technique, although there may be others that can do the trick, or you may be able to modify your own to suit your style. I use B2 through B6. If you want to see a close up, let me know Is there somwwhere online I cant get those? With worldvide shipping? Quote
