Members superpacker Posted July 2, 2018 Members Report Posted July 2, 2018 I've read some mention that a special setter is needed to set stainless snaps. Is that true, or just an attempt to have you buy another snap setting tool? Or can I use the normal Line 20 tool I already have for standard brass/base metal snaps? If not, can a press be used? Thanks! Quote
Members KooperLee Posted July 18, 2018 Members Report Posted July 18, 2018 If you want not only the snaps hold your products firmly, but also the snaps look professionally well-done. Then you might need a special setter people also call them dies or die sets like what I attached. But to apply the die sets, you also a press. You can try this post http://www.dot-gas.com/wordpress/?p=759 if you want to get more idea. Quote ELEMENTRIMMING / DOT-GAS
Members Treesner Posted August 2, 2018 Members Report Posted August 2, 2018 was wondering if its a sales pitch as well.. Osborne said I needed a social tool to set the stainless grommets (tool is double the price of normal) Quote
alpha2 Posted August 2, 2018 Report Posted August 2, 2018 Tandy also specifies a higher grade setter for stainless snaps. If you have a regular set, you can try a couple of snaps and see if it works for you. Quote So much leather...so little time.
Members DrmCa Posted August 3, 2018 Members Report Posted August 3, 2018 SS is harder than brass. Having said that, I am setting SS or brass of the same size on the same set of dies and never felt SS were set any different. They may cause extra wear on the die set, but it usually lasts several 10s of 1000s of snaps at least, so why bother? Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members csosborne Posted August 8, 2018 Members Report Posted August 8, 2018 On 8/2/2018 at 7:24 PM, Treesner said: was wondering if its a sales pitch as well.. Osborne said I needed a social tool to set the stainless grommets (tool is double the price of normal) good morning, this is Daniel with C.S. OSBORNE & CO. the reason for this is in the past we sold our regular dies to customer and had complaints about the die wearing out with a few uses. about 2 years ago or so we made a special die for the stainless grommets to withstand d the material. these dies are special made and harden to the right specs. You can use the regular die if needed but it would wear and tear because the stainless steel is stronger then the high grade steel die. any questions please feel free to contact us at: cso@csosborne.com thank you Daniel sales Quote
