I can acquire either of these for $1000 CDN and for that price - (both n working order and recently serviced and set up for leather work) - the Pfaff I will need to put an old clutch motor on for now but the Adler comes with a servo so....
Which would you take?
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
Negotiate.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Assuming both machines are in equally good shape the Pfaff is going to cost more (clutch motor, installation time and future servo motor). Unless you are use too clutch motors remember they can be most unforgiving when it comes to speed control. There is nothing worst then having a momentary concentration lapse or a foot twitch and having your work ruined.  For that reason alone I would probably consider the Alder over the Pfaff and besides it is ready to sew. Whether either machine is the right machine is going to depend on budget (I think the price is a little high for either) and what you are mostly going to be using it for (upholstery or holsters and availability / cost of what attachments you may need). I will leave the sewing capabilities of the machines to more experienced people.
kgg
Yes,
The Pfaff needs a servo motor.  However, the 1245 uses a larger bobbin and it is a smoother machine.  I have had and sew on both a Pfaff 1245 and  a Adler 267, not a 67GK373.  The Pfaff is a better machine especially if it is a German made one IMHO.
glenn
I have to agree with Glenn. If given the choice between a Pfaff and an Adler I will take the Pfaff every time. I just find the Pfaff machines to be smoother in operation, but that's just my opinion.
Regards,
Joe Esposito
www.hockeymenders.com
instragram: @hockeymenders.com
I also think I we "prefer" the Pfaff but the Adler deal is now adding a sew quiet servo, speed reducer, foot kit, and lots of other extras....
Thanks all for the input so far. Stay tuned.....
plinkercases.ca
With either of these choices, do you typically use the 190 system needles.
Thanks and have a good day
Floyd
I believe both are 134-35 system needles.
plinkercases.ca
Out of curiosity what are you going to be using the machine mostly for?
kgg
6 oz veg tan belt case/sheath products no more than three layers (3/8ths is fine) belts and some flat stuff made out of upholstery leathers.
Even harder to make a choice now that the adler deal had some extras added and i confirmed the pfaff is a class H3 C which is the third of four levels for medium duty taking needles from 120 to 160 and thus 207 thread......
plinkercases.ca
