Members spacedog Posted August 12, 2018 Members Report Posted August 12, 2018 I started working on a gorget with some viking boats going over choppy waves. The boats we not too hard to figure out, but the water and waves ended up a lot more difficult. If anyone has some experience or a good method for water I would love to hear it. Quote
Members EmilyEstelle Posted August 12, 2018 Members Report Posted August 12, 2018 Hi, I might be able to help a little with the water. Its easier if I show you on your own piece of art what I'm talking about so I hope you don't mind if I drew over the top of it.. First, because of the perspective your longboats are at, there would *likely* be a horizon line behind them at some point, which I added. The big waves became the mid-ground, they show you how wild the ocean is. Because the swells you made were so large, and you implied a lot of big splashing, that should carry over into the rest of the water. Adding some whitecaps makes it look windy, stormy, wild. Toward the horizon the waves are almost indiscernible, but they should get larger and more pronounced as they get closer. Where the boats are breaking the waves, the water breaks at the prow, spraying up, and back. Just adding some lines that show motion helps with that. Hope this helps, and hope you don't mind me drawing over the top of your image. D: Emily Quote
Members ScoobyNewbie Posted August 13, 2018 Members Report Posted August 13, 2018 Wow! Gorgeous! Both of them! Quote
Members spacedog Posted August 13, 2018 Author Members Report Posted August 13, 2018 5 hours ago, EmilyEstelle said: Hi, I might be able to help a little with the water. Its easier if I show you on your own piece of art what I'm talking about so I hope you don't mind if I drew over the top of it.. First, because of the perspective your longboats are at, there would *likely* be a horizon line behind them at some point, which I added. The big waves became the mid-ground, they show you how wild the ocean is. Because the swells you made were so large, and you implied a lot of big splashing, that should carry over into the rest of the water. Adding some whitecaps makes it look windy, stormy, wild. Toward the horizon the waves are almost indiscernible, but they should get larger and more pronounced as they get closer. Where the boats are breaking the waves, the water breaks at the prow, spraying up, and back. Just adding some lines that show motion helps with that. Hope this helps, and hope you don't mind me drawing over the top of your image. D: Emily Thanks Emily. This helps a lot. I had some of the splashing around the left boat, but need to do the same for the rest. The wave caps look great, and the horizon line too. Hopefully I can fix this now. Thanks very much. Quote
Members spacedog Posted August 15, 2018 Author Members Report Posted August 15, 2018 Again, a big thanks to Emily. I think your suggestions made a big difference. Here are a couple photos to update: On 2018-08-12 at 2:54 PM, kiwican said: I like this Thanks. On 2018-08-12 at 7:56 PM, ScoobyNewbie said: Wow! Gorgeous! Both of them! Thank you. Quote
ABHandmade Posted August 15, 2018 Report Posted August 15, 2018 Now the sea and waves turned out very believable. Great work! Quote
Members Ragingstallion Posted August 15, 2018 Members Report Posted August 15, 2018 Hey, that is looking great. I look forward to seeing it complete and in use. Quote
Members EmilyEstelle Posted August 16, 2018 Members Report Posted August 16, 2018 That is a vast improvement Quote
Members tnhart78 Posted August 31, 2018 Members Report Posted August 31, 2018 Amazing! Quote Tony Any task, no matter how difficult, can be broken into many simple steps.
Members DJole Posted August 31, 2018 Members Report Posted August 31, 2018 Such a helpful community -- you got some great instruction there, and it looks really nice! Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members spacedog Posted February 3, 2019 Author Members Report Posted February 3, 2019 Thanks for the comments everyone. I took an extended break from this project due to frustrations with it. At any rate, I finally pushed on and finished it. I dyed it fairly dark, maybe too dark, but I am happy with the result. It is a costume piece, not intended to be real armor. I hope you like it. Quote
Members spacedog Posted February 4, 2019 Author Members Report Posted February 4, 2019 20 hours ago, Sceaden said: Beautiful work! Thanks. Quote
Members EmilyEstelle Posted March 4, 2019 Members Report Posted March 4, 2019 That looks really cool Quote
Members spacedog Posted March 4, 2019 Author Members Report Posted March 4, 2019 7 hours ago, EmilyEstelle said: That looks really cool Thanks. Quote
Members Gezzer Posted September 22, 2022 Members Report Posted September 22, 2022 OUTSTANDING !!!! and again Thank you , like you I had to take a break but this will prompt me to start again . Quote
