No one has mentioned the old cobblers lace maker.  I have one and it works fine.. stole a photo off the net.
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
I thought that was the Australian Strander O_o
17 hours ago, Grihm said:
Kudos for the info!
Il be trying out the Strander one i feel. If it´s not what i hope for, il probably go for the old antique one that makes rounded lace, but they too are quite expensive. Oh well... trial and error i suppose. Also, may be different with my veg tanned leather so i´l be sure to take note on it.
Rein rounder ity was called. I call it lace maker in Sweden but i hope it makes sense anyways. Adding a pic.
9323_-_Randall_15_hole_rein_rounder__450 (1).jfif
Australian lace maker.....  you are right!!  I'd gotten mine so long ago I forgot the name.   They came out of an Amish harness shop in southern Wisconsin.
Awesome! I like the look of it as well since it´s no plastic.
Question. Can you use it as the Tandy plastic one as well? I mean to make leather cord from a round piece starting from a center hole?
But the REAL question is, WHERE is the tool that reliably BEVELS the lace?
5 leather patterns
Any version  of these? Or do you mean bevels it at the same time?
nah, I mean so that the lace,
Untitled-1.jpginstead of being this
Untitled-2.jpggets to be this
So when I lace with it (not  braid with it) it lays FLATTER (for buckstitching)
5 leather patterns
Then that´s the tool you use. At least as i see it from your pic. Could also be this one as it works on a broader surface.
That would be quite a trick considering that the lace would be less than half as wide as that tool.  I don't doubt it would make the cut, but you'd need a way to reliably hold the lace straight without stretching ...
5 leather patterns
