garypl Posted September 10, 2018 Report Posted September 10, 2018 I have a problem with a Consew 206RB-4 reverse stitch length and I hope someone can give me some tips. The reverse stitch length is @1/2 the length of the forward stitch length. I followed this video trying to adjust the reverse stitch length starting around 1:26 in the video. Problem is that the Feed Regulator Rod (item 35 in parts list under Feed Regulator section) will not move. I loosen the Pinch Screw (item 2) but cannot get any movement in the Rod. I sprayed the assembly with penetrating oil in case the whole assembly was frozen, but no help. Has anyone else had a problem with this adjustment? For now I have just been turning the workpiece around to back stitch, but sure would be nice to be able to reverse backstitch. Here is a picture of the screw and rod, looking down from the oil reservoir on the top of the head. Thanks for the help! Gary Quote Cowboy 4500, Consew 206RB-4
Members Gregg From Keystone Sewing Posted September 10, 2018 Members Report Posted September 10, 2018 This is one rare case that a 206RB-5 does not have the same adjustment than the -4 models. They are very different, see attached parts page for the -4 machines. 206RB-4Parts_Pages.pdf Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
garypl Posted September 10, 2018 Author Report Posted September 10, 2018 Thanks Gregg. I see the difference- do you have a procedure on how to adjust the stitch length so forward and reverse are equal? Gary Quote Cowboy 4500, Consew 206RB-4
Members Gregg From Keystone Sewing Posted September 11, 2018 Members Report Posted September 11, 2018 (edited) It's kind of locked in without anyway to adjust this area. I would look for something else here, really have to see the machine. Edited September 11, 2018 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
garypl Posted September 12, 2018 Author Report Posted September 12, 2018 Thanks Gregg - I will search around for more information. Must be a way to equalize forward and reverse stitch length. Gary Quote Cowboy 4500, Consew 206RB-4
Members TreTreez Posted January 28, 2019 Members Report Posted January 28, 2019 having same problem did u find out how? Quote
garypl Posted January 30, 2019 Author Report Posted January 30, 2019 On 1/29/2019 at 3:38 AM, TreTreez said: having same problem did u find out how? Never did figure out how to adjust - I have just been turning the piece around to backstitch. I haven’t done much of anything lately with my machines - been busy working and traveling on business. Will be home on Friday, hope to find some time to play a bit! Gary Quote Cowboy 4500, Consew 206RB-4
Members TreTreez Posted February 14, 2019 Members Report Posted February 14, 2019 I started over with this video Like Greg said it a locked machine but movimg the feet to the right settings help alot.Hope it helps you as will Quote
garypl Posted February 15, 2019 Author Report Posted February 15, 2019 21 hours ago, TreTreez said: I started over with this video Like Greg said it a locked machine but movimg the feet to the right settings help alot.Hope it helps you as will This is a good video - I’ll go through the adjustments again when I have time. Gary Quote Cowboy 4500, Consew 206RB-4
Members katit Posted February 15, 2019 Members Report Posted February 15, 2019 Yep, this is the video where guy says you can’t setup forward/ reverse to be equal in all stitch lengths. Which is not correct. Quote
