Members CEA Posted September 11, 2018 Members Report Posted September 11, 2018 I'm looking at a local Singer 111w155 and my web research says those machines came with triple feed but the guy says it has a walking foot but not a walking needle. Has anyone ever seen a 11w155 without a walking needle? Thanks in advance for your help. Chris Quote
Members R8R Posted September 11, 2018 Members Report Posted September 11, 2018 The 111W's are compound (triple) feed. Needle feed, inner foot feed, feed dogs, all synchronous. If his does not have a needle feed it's not really a 111W, or it's broken. Quote
Members Constabulary Posted September 11, 2018 Members Report Posted September 11, 2018 There were 111 with just needle feed (meaning bottom feed and needle feed combined and not moving presser foot) and the 111w141 had just drop feed (no walking needle and no walking foot) but all 111w155 had triple feed and that includes the "walking needle". Maybe stitch length is adjusted to zero? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Gregg From Keystone Sewing Posted September 11, 2018 Members Report Posted September 11, 2018 Maybe it's possible someone is confused where they installed a single presser foot for drop feed use? Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members CEA Posted September 15, 2018 Author Members Report Posted September 15, 2018 (edited) Wow everyone, thanks for all the feedback. Exactly what I want to hear! So the seller doesn't know his sewing machines very well. I'll take a look at it and see what kind of shape it's in. Any particular vulnerabilities on a 111w155 that I should watch out for? He has it listed as a 111w155-7. What is the significance of the -7? I'm sure this has been answered a bunch but where would I find a good value on a servo motor for this machine? Thanks Chris (GREAT forum by the way!) Edited September 15, 2018 by CEA Quote
Members SARK9 Posted September 15, 2018 Members Report Posted September 15, 2018 If this is the same machine, it shows no "-7" subclass on the tag: https://classifieds.ksl.com/listing/52874558 Difficult to say, but it does look a bit like it has the paddle-type foot mount from a needle feed like you would expect on a 111W151 etc. It has a non-standard bobbin cover plate and a zillion tapped holes for custom fixtures, plus a repaint, so I would guess it has seen some customized/specialized service on a factory line and all bets are off as far as what is "original" with that sort of history. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members CEA Posted September 15, 2018 Author Members Report Posted September 15, 2018 SARK9, Yeah that's the one. I hadn't notices the tapped holes but there are LOTS. When you say: all bets are off as far as what is "original" with that sort of history wouldn't mean they might have taken out the walking needle would it? I'd hate to drive all the way down there and find a machine that isn't triple feed. If you were buying this machine what would you look at to make sure it's in good shape and what questions (and the answers) would you ask the seller? Thanks for your help. Quote
Members SARK9 Posted September 15, 2018 Members Report Posted September 15, 2018 (edited) I really don't know what type of foot is installed on that machine...I just don't recognize it as any of the typical 111W types that are simply everywhere. Though I've not tried it myself, I believe you can unclamp the presser foot bar and rotate it 90 degrees to use the "paddle" type feet, so that may not be too much to alter. Disconnecting the "walking" (outer) foot motion to use that type of foot would be possible if desired, but the inner foot, needle and feed dog would need to remain in synch like a needle feed machine. If the only thing that is left functional is the feed dog, why would you want it at all? The button for locking the mechanism to adjust the stitch length has also been removed, another strong hint that the machine has been used for a dedicated custom operation making a specific component in a factory setting. Its possible all the feed mechanisms have been altered for use with an external puller. Personally I wouldn't drive across town for it, or offer any more than a K-leg stand and a salvage casting was worth to me. These machines in good condition are frequently available for a third of the ask. Just sayin'. Here is a prospect listed with the same service: https://classifieds.ksl.com/listing/53555838 -DC Edited September 15, 2018 by SARK9 Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Albob Posted September 15, 2018 Report Posted September 15, 2018 I have a 11W155 and like SHark9 said the one you see in the CL add is highly modified definitely not worth the asking price. For that money I bought myself nice well maintained 111W155 and had enough left over to get the servo conversion. I'd say pass on that one and look around for one that will do belts (2 layers of 3-4) Wallets are no problem and some light weight holsters are even possible with care. Good luck Quote When the poop hits the fan, we's all eleven bravos
Members dikman Posted September 15, 2018 Members Report Posted September 15, 2018 Actually, it's quite an intriguing machine, given that it's obviously not quite a stock standard unit. The spool holders are mounted underneath the table (??) and there's a linkage of some sort hanging across the foot pedal. I'd also noticed the repaint, probably not too old given that it's not showing any wear, and as for all the extra holes........ I'd be interested, but not at that price, given its "peculiar" condition. Probably not a good idea for someone just starting out, you want a machine that is hopefully in at least "standard" condition which will make it easier when you inevitably ask for some assistance/advice. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
