Members Spade Posted October 5, 2018 Members Report Posted October 5, 2018 I have a tech sew 2700 that breaks the thread at the needle every time. Very frustrating at this point. I’m using 138 thread with the proper needle size, I’ve tried adjusting the tension every way possible with no luck. Also noticing that the thread is coming out of the last tension roll as it is getting slack there. I don’t know if I explained this very well as I’m new to this sewing adventure. Quote
Hockeymender Posted October 5, 2018 Report Posted October 5, 2018 Check your needle for burrs, that will shred thread. Quote
Moderator Wizcrafts Posted October 5, 2018 Moderator Report Posted October 5, 2018 Is the thread passing around and into the check spring and is the spring's range of motion holding it taut until the needle pierces the material? Quote
Techsew Ron Posted October 5, 2018 Report Posted October 5, 2018 11 minutes ago, Wizcrafts said: Is the thread passing around and into the check spring and is the spring's range of motion holding it taut until the needle pierces the material? Here's what the threading of this area should look like. Quote
Members brmax Posted October 5, 2018 Members Report Posted October 5, 2018 Is your thread breaking at a certain point. Or during a function like back tac, or turning the material piece around. This could help a bit in the trouble shooting. Good day Floyd Quote
Members Spade Posted October 16, 2018 Author Members Report Posted October 16, 2018 Sorry for the late response, had to go back to work. So I checked the things asked & found that I didn’t have the thread coming around the bottom tension spool properly. I had a #23 needle & changed to a #24. This seams to have helped I was able to sew 2 lengths of 14” with out breaking the thread. I’m just working on getting the tension set properly. Thanks Very much for the replies Warren Quote
DonInReno Posted October 16, 2018 Report Posted October 16, 2018 Hang in there - figuring out problems can be frustrating. Quote
Members chrisash Posted October 16, 2018 Members Report Posted October 16, 2018 My chart nshows size 22 for 138 thread Quote
Moderator Wizcrafts Posted October 16, 2018 Moderator Report Posted October 16, 2018 I prefer a #23 needle with #138 thread, top and bottom. Quote
