Members arz Posted October 17, 2018 Members Report Posted October 17, 2018 We finally bought a sewing machine! Thanks for all those who have answered my previous questions. Now the fun part, learning how to use it We bought it from a lady who makes purses and wanted more room (she has a Pfaff 1245 and Adler 269-373). We paid 430 Euro ($500) with Jack servo and flat table attachment. She used it with thick threads and the stitches look good. She also gave me the number of her mechanic so he can come adjust it for us. It worked great when I tested it but I am already running into problems...to be expected since this is our first sewing machine. Can anyone tell me if this is a 69-373? The model plate is gone. It seems the the top right tension spring is missing and the tension release is not working. I am trying to get a list of parts to order. If anyone sees some parts missing or set up wrong please let me know, I would appreciate it! I also have some very basic questions, should I post questions here or start a new topic? Thanks! Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members R8R Posted October 17, 2018 Members Report Posted October 17, 2018 Check your threading, looks like you are bypassing the check spring. Quote
Members arz Posted October 17, 2018 Author Members Report Posted October 17, 2018 2 minutes ago, R8R said: Check your threading, looks like you are bypassing the check spring. Thanks! I think I see what you mean. Are you talking about the tension spring on the far left (the one with the wire loop).? I took these photos as the previous owner had it threaded. When I rethreaded it I put the thread under that spring/wire. Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members R8R Posted October 17, 2018 Members Report Posted October 17, 2018 When you say "top right tension spring" which part do you mean exactly? Close up pics help. Threading vid: https://www.youtube.com/watch?v=_J1b57wIdIQ Quote
Members arz Posted October 17, 2018 Author Members Report Posted October 17, 2018 (edited) 12 minutes ago, R8R said: When you say "top right tension spring" which part do you mean exactly? Close up pics help. Threading vid: https://www.youtube.com/watch?v=_J1b57wIdIQ Thanks! I have watched that video. I think I have it threaded right. I have attached a photo with the tension part I am talking about. In the parts diagram it shows a few more rings (edit: disks) and a spring. I just have one disk (more like a washer). Do I need to have this spring and disks here? I aslo removed the screw just below and left of the part in red. This was preventing the tension from releasing when you lift the foot....not sure why they did that? Edited October 17, 2018 by arz Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members jimi Posted October 17, 2018 Members Report Posted October 17, 2018 You did not mention what exactly is wrong?? Quote
Members dikman Posted October 17, 2018 Members Report Posted October 17, 2018 It should go under that check spring (wire loop), Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members R8R Posted October 17, 2018 Members Report Posted October 17, 2018 Yeah this is not threaded correctly, please watch the vid and go through each step, it's pretty clear. The thread needs to go under the check spring wire. Also yes that first disc is a pre-tensioner and it needs a spring to operate correctly, although you can compensate for it in the meantime by threading it through all the holes of the thread post on top of the machine. (each loop through adds a little tension) Quote
Members arz Posted October 18, 2018 Author Members Report Posted October 18, 2018 7 hours ago, dikman said: It should go under that check spring (wire loop), Yes I understand. As I said in a post above, this photo was taken when I just got the machine (as the previous owner had it), and I rethreaded it as in the video. Thanks! 7 hours ago, R8R said: Yeah this is not threaded correctly, please watch the vid and go through each step, it's pretty clear. The thread needs to go under the check spring wire. Also yes that first disc is a pre-tensioner and it needs a spring to operate correctly, although you can compensate for it in the meantime by threading it through all the holes of the thread post on top of the machine. (each loop through adds a little tension) Thanks! That is what I wanted to know. I will order the rest of the parts for that first tension discs. Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members Ski Posted October 18, 2018 Members Report Posted October 18, 2018 I bought what looks like the same machine a week ago. My first industrial! Exciting right? Quote Warm regards, Mark Skiba
