Members CutThumb Posted October 29, 2018 Members Report Posted October 29, 2018 Hi all, I got to the stage of having cut out, and carved, a notebook cover before I spotted this half inch split. Note to self - check the bloody leather before you start! Anyway, am planning on gluing it with rubber cement. Should I do this before or after dyeing? Or should I use something else altogether? I’m going to dye with Fiebings pro, and use a leather conditioner afterwards. As always, all advic gratefully received. Quote
Members rodneywt1180b Posted October 29, 2018 Members Report Posted October 29, 2018 Ok. I replied to the wrong thread. I'll edit that. I see now why you didn't notice it. It's not as bad as I thought. Will the back side show? I would seriously consider a thin liner on the inside. I can't help with the dye question. Quote
Members battlemunky Posted October 29, 2018 Members Report Posted October 29, 2018 Rubber cement/Tanner's Bond type stuff works reeeeally well. I'd imagine it would hold pretty well and for a long time. I'd do it before dying it. Maybe a stitch or two could be used without detracting from the piece as well, a talking point perhaps? It'd all depend on the customer I suppose. Quote
Members Sheilajeanne Posted October 29, 2018 Members Report Posted October 29, 2018 (edited) Yeah, if you can arrange your piece so there is a stitch line over the edge of the split, I imagine that would help keep it in place. I'd be careful when burnishing though - too much pressure might cause the split to open up again. Edited October 29, 2018 by Sheilajeanne Quote
Members CutThumb Posted October 29, 2018 Author Members Report Posted October 29, 2018 Great advice, thanks. I could sew a pocket into the back, as it’s a travelling journal and, hey, pockets... Yeah the guy will be cool about it, he’s a friend. No way I could not use it as it’s currently the best bit of carving I’ve done to date, somewhat typically. And Rodney, don’t know how I double posted! My iPad does random stuff whenever it feels like it! Quote
Northmount Posted October 29, 2018 Report Posted October 29, 2018 Any glue/cement that is visible won't dye. So I would dye whatever is visible first. Tom Quote
Members rodneywt1180b Posted October 29, 2018 Members Report Posted October 29, 2018 39 minutes ago, Northmount said: Any glue/cement that is visible won't dye. So I would dye whatever is visible first. Tom That's my experience with wood glue and finishes too. The glue seals the pores and won't let any stains or dyes penetrate. Quote
Members VabaX Posted October 30, 2018 Members Report Posted October 30, 2018 If you're planning on burnishing that edge, I would steer well clear of any kind of rubber glue or contact cement, and its does not like being burnished over when its present in thick quantities (eg, any thicker than very light smear). I would use standard white wood glue, as it sands away easily and offers no issues to being burnished over. you'll just have to clamp it down for a short while as it dries. Quote
Members CutThumb Posted October 30, 2018 Author Members Report Posted October 30, 2018 8 hours ago, VabaX said: If you're planning on burnishing that edge, I would steer well clear of any kind of rubber glue or contact cement, and its does not like being burnished over when its present in thick quantities (eg, any thicker than very light smear). I would use standard white wood glue, as it sands away easily and offers no issues to being burnished over. you'll just have to clamp it down for a short while as it dries. Ah, Ok. Yes I was intended on burnishing. I’ll give the wood glue a go, thanks. Quote
Members Constabulary Posted October 30, 2018 Members Report Posted October 30, 2018 This is most likely not a qualified answer - but - has someone ever tried Transglutaminase (so called "meat glue") for gluing leather? Wild idea I know... Just wondering... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
