Members Cascabel Posted December 10, 2018 Members Report Posted December 10, 2018 (edited) Get a short screwdriver that uses 1/4 inch replaceable tips. Choose a tip that is a PERFECT fit in the slot, or grind a little to get a PERFECT fit. Use the screwdriver handle to exert STRONG downward pressure, and turn it using a 1/4 inch wrench directly on the tip. That usually works for me. If you have already boogered up the slot, then all bets are off !! Edited December 10, 2018 by Cascabel misspelling Quote
Members Itch Posted December 10, 2018 Members Report Posted December 10, 2018 22 hours ago, Hockeymender said: I’ve had success with Kroil oil. I have rebuilt a few Old Motorcycles and Kroil is the best thing on the market .. Quote Quality leather goods www.captain-itch.com www.Tennesseeholstercompany.com
Contributing Member Samalan Posted December 10, 2018 Contributing Member Report Posted December 10, 2018 The best penetrating oil i have ever used is a mix of 1/2 Break fluid 1/2 acetone very slight tap's very tiny hammer . Quote
Members dikman Posted December 10, 2018 Members Report Posted December 10, 2018 The other one that a lot of people swear by is 50:50 Auto Trans Fluid and Acetone. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Kryptonite Posted December 10, 2018 Author Members Report Posted December 10, 2018 (edited) Thanks to everyone for their input... you guys are the best. I got every screw out with almost no damage. All the screws soaked overnight in PB Blaster. The 2 needle plate screws came out with a sharp little hit from corner of a chisel, great tip Bob, it was the ticket! The 2 tiny gib screws holding the bobbin case needed 20-30 little taps of a small hammer hitting a screwdriver seated in the slot, mimicking a vibration thing. The machine sews great - money well spent. Thanks guys, Will in Central Florida Edited December 10, 2018 by Kryptonite Quote
