Thank you.
clients%2Fabo%2Fphoto_sets%2F117168%2F_t clients%2Fabo%2Fphoto_sets%2F117168%2F_t
Looks like a bobbin winder. Not sure what machine it would go to though. What is the part number on it? Can't make it out from photo.
Edited by suzelle
Maybe for a Singer Class 6 or 7.
It's the bobbin winder from a Singer 132K. I can only make out the "41896" number in the pictures above, but it matches the parts diagram of the Singer 132K.
Looks like yours is missing the rubber "tire" that should sit in the groove and provide friction against the handwheel.
Here's the picture from the SInger 132K owner's manual (Singer 132K Manual.pdf)
This page is from the Singer 132K parts list (132K6_10_12.pdf)
Edited by Uwe
Thank you one and all.
Uwe, you nailed it, great information.  Thank you.
Thank you Suzelle and thank you Machinehead.  Looks like the Singer Class 7 uses a similar part also .
Expand
It also looks near exactly like the one on my Adler 20-2  even the base.
Singer 7 or 97 and Adler 20 winder have a longer pin for the bobbin and a wider filler tongue /stop latch. I´d also say Singer 132K / 133K but the coil spring is missing. Yes friction leather strip is missing too, they were attached with brass pins.
@ Constabulary  Good to know.  Thank you.
@ Catskin   Thank you.
  • 4 years later...
I do have the similar types on my my class 7-33 but its missing its wheel  and on my 132 k6 they look very similar to each other here is a pic but missing wheel  class 7
I don´t think you can get the OEM wheels anymore (well maybe... you never know). If I were you I would probably take a wheel from a different bobbin winder then wrap a piece of leather or PU flat belt around it and adapt it to the spindle. Spindle is present I guess?
Other than that I would buy a table mount bobbin winder
https://www.ebay.com/itm/143422223667
But it may need some modification as well.
Edited by Constabulary
Expand
Thought I may just get a old cast pulley wheel and find a spindle from some of my old metal bar from vintage machines I had, and either rubber or leather in the gap of the pulley, I have do have some old cast table bobbin winder,
I never was lucky enough to have a metal lathe , It would of been useful ,in my tinkering with machines
Edited by 1985
