RockyAussie Posted April 15, 2019 Report Posted April 15, 2019 10 hours ago, dikman said: All this waffle is to say that the little laser let me do something that I couldn't have achieved otherwise. Firstly I will say that the cover has come out very nicely. As to your last comment I think that hardly any here, could have achieved that level of detail in the badge part without the laser process. Those that could..... would not come near to doing it for a price that all but a very few could pay you for. WELL DONE!!! Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members dikman Posted April 15, 2019 Author Members Report Posted April 15, 2019 Thanks mate, I was about to make a similar comment about the detail in the emblem. There's NO way I would even attempt that if I didn't have the engraver. Likewise with the name etc, my stamps are all too big. While I like the idea of something being entirely handmade, realistically cost can sometimes become an issue. I have no qualms about using modern technology within reason, although I must admit I still like handstitched items compared to machine stitching. I've been looking at Lightburn, but I'm not sure it's designed to work with these little engravers as it requires specifying the hardware/firmware being used and I have no idea what this thing uses! I have found some software called Scarve so I'll try that. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
RockyAussie Posted April 15, 2019 Report Posted April 15, 2019 5 minutes ago, dikman said: I have no qualms about using modern technology within reason, although I must admit I still like handstitched items compared to machine stitching. I agree with that mostly when I see products stitched poorly but that can be evident whether by hand or machine and I prefer to do it well enough by machine that an educated eye has difficulty telling which way it is done. NOT saying I always achieve that level 8 minutes ago, dikman said: I have found some software called Scarve so I'll try that. I will have a look but if you have not checked out T2 laser do so as well. One of the features I have useful is being able to set it to do multiple passes with a cool down time in between passes. Sometimes cardboard or leather will lift and buckle as it is cut and by doubling the speed or halving the power you can get a chance to put down some more weights or magnets in my case. This also allows me to keep the temperature down when using full power on long jobs. Next update on mine will be a vacuum bed to keep it down flat. I hope by going to a larger blower I can share the smoke extraction with the bed vacuum in a split sort of way. Only got a talk myself into drilling about a thousand 3mm holes through about 2mm steel sheeting... Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Halitech Posted April 15, 2019 Members Report Posted April 15, 2019 39 minutes ago, RockyAussie said: I agree with that mostly when I see products stitched poorly but that can be evident whether by hand or machine and I prefer to do it well enough by machine that an educated eye has difficulty telling which way it is done. NOT saying I always achieve that level Exactly. Just because it was stitched by hand, doesn't mean it was done well or done properly. I talk to a lot of people that seem to think saddle stitch is basically a running stitch done with 2 threads. The way I was taught, saddle stitch actually locks in because of the knot that gets tied in the middle of the hole. And when done properly, hopefully you can't tell if it's by hand or machine Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members dikman Posted April 16, 2019 Author Members Report Posted April 16, 2019 You probably won't need that many holes for the vacuum to hold it down, another way might be to use a thin cut-off wheel in the grinder and cut a series of thin slots instead of holes? It would be quicker and easier than drilling lots of holes and should work. Looks like Lightburn is a no-go, it can't recognize the device. I mentioned Scarve before but that looks like it's an even simpler bit of software than what I have! Guess I'll just have to stick with what I have, while it has its limitations it's not too bad - when it works. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted April 16, 2019 Author Members Report Posted April 16, 2019 Scarve didn't work, but I don't like the simple interface anyway. Guess I'll just work with what I've got. The customer liked the folder so now wants me to make him one. This time I'll leave it as "natural" colour, neatsfoot oil should darken it just enough to give it that warm look and let the engraving stand out. This one should be quicker now that I know what I'm doing. He said others might want one too but I said any more will cost more than I'm charging him! This engraver might be "cheap" and have flaky software but I'm impressed with what it can do (it can also cut stencils out of card, so that's got me thinking). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
RockyAussie Posted April 16, 2019 Report Posted April 16, 2019 14 minutes ago, dikman said: This engraver might be "cheap" and have flaky software but I'm impressed with what it can do (it can also cut stencils out of card, so that's got me thinking). Next you'll be needing another one or 2 to keep up. (Don't forget it cuts the masking tape on leather nicely).The variety of things that are possible are just mind blowing. Biggest headache so far with mine is that it is stuck cutting out product boxes nearly all of the time and I cant get to try enough of that more interesting stuff. Think I might have to make another smaller one next and try and squeeze it in somewhere........... Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members dikman Posted April 17, 2019 Author Members Report Posted April 17, 2019 Yep, sounds like you definitely need another one! I'm not overly interested in making too much for sale, it's too much like work! The only reason I'd do any is that it's an excuse to make things. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members chrisash Posted April 17, 2019 Members Report Posted April 17, 2019 Is there enough finess to copy photo's of family etc onto leather goods say wallets or belts and so on? Quote Mi omputer is ot ood at speeling , it's not me
Members dikman Posted April 17, 2019 Author Members Report Posted April 17, 2019 The limiting factor is the type of material and the settings used to burn in. That logo I did was scanned from one on a police notebook. When I did a trial run on cardboard the detail was quite sharp, but burning onto leather lost a little bit (not much) detail, due, I guess , to the fibrous nature of leather. Burning a photo image onto leather it would certainly be recognisable but don't expect it to look like a photo. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
