Guy I work with has a seecamp and wanted a better pocket holster. Figured it's a super small gun and would be a good starting point to put some ideas into fruition.   Here is the front showing the spring steel strip that I intend on trapping between layers. Also want to try some "buffed" leather for the outer layer to grip the pocket.
60281709_10214413329394756_7231159629927
Here is the back   guessing I will have to mold the first layer to the mold gun then glue on the buffed to make the gun not print in the pocket.
60402472_10214413327914719_2692387179635
My guess is that the spring steel will make his pocket stand out, . . . let him try it without the steel, . . .
I always make mine with the rough side out, . . . like you are doing
The double stitched piece up front will hit the top of the pocket, . . . strips off the holster, . . . works perfect every time.
Do a light molding of the gun, . . . then after it dries, . . . wiggle it hard back and forth to loosen it up, . . .
May God bless,
Dwight
www.dwightsgunleather.com
If printing is an issue, you can do this...
So much leather...so little time.
That is where I may end up!
I have a few different sized guns to try this with so a flat plate might be the best route.
Kudos to Jeff for posting his design.  I made one for my S&W Bodyguard and keep it in my front pocket.  Looks like a large square wallet or phone with no printing of the pistol at all!
Gary
Cowboy 4500, Consew 206RB-4
