Members LyndHoll Posted May 16, 2019 Members Report Posted May 16, 2019 (edited) I have a Singer 31-15. Had it sewing beautifully with #92 thread. Switched to #69 & the bobbin thread is looping BADLY. I noticed that after a couple of stitches, the thread is jumping out of the tension discs. I've tried adjusting the tension on the discs, thread still jumps out. It seems as if it needs more tension before the discs to keep it between the discs. I appreciate any suggestions you experienced folk have, however, I'm not a sewing machine repair person, or by any standard an expert, so simple answers will be the most helpful. I'm not up on the technical terminology. Thanks! Edited May 16, 2019 by LyndHoll Add photo Quote
Members Gymnast Posted May 16, 2019 Members Report Posted May 16, 2019 Often when you put in smaller thread in bobbin, you need to adjust the lower tension, because it will be too low. Did you do that? Quote Sewing Machines in Detail, YouTube channel
Members LyndHoll Posted May 16, 2019 Author Members Report Posted May 16, 2019 Thanks for the reply. I did try that. Quote
Members Gymnast Posted May 16, 2019 Members Report Posted May 16, 2019 And I have to ask - no offense - did you remember to lower the presser foot? I got your Picture in my head from forgetting that. Quote Sewing Machines in Detail, YouTube channel
Members LyndHoll Posted May 16, 2019 Author Members Report Posted May 16, 2019 Yep. It's a knee lever, so not hard to remember that. Quote
mikesc Posted May 16, 2019 Report Posted May 16, 2019 (edited) If there are any posts with holes in that you can wind the thread around before the tension discs, wind it through more holes than you did for the #92..and check that the tension discs are working properly that he spring is not broken, and that the little bar ( it lives inside the machine.is like a thick needle but shorter and with no point..it pushes through the disc which is nearest to the machine onto the discs which is acted upon by the tension spring, thus it pushes them apart to release the tension when the foot is lifted..it can break, bend, stick , drop out, get kidnapped by aliens, ) that pushes them apart to release them when the foot is lifted has not stuck or broken..Looks and sounds from your description and image, like your tension discs are not closing up correctly.. Edited May 16, 2019 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members LyndHoll Posted May 16, 2019 Author Members Report Posted May 16, 2019 Mikesc, thanks for the reply. That makes sense. I'll look into these recommendations. Quote
CowboyBob Posted May 16, 2019 Report Posted May 16, 2019 The most common cause for looping underneath is improper threading(make sure it's pulled all the way between the discs) or too loose of tension. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members LyndHoll Posted May 16, 2019 Author Members Report Posted May 16, 2019 We are back in business! Thanks for the help. Prettiest stitch since I bought the thing. I have so much appreciation for everyone who watches the forums and responds with suggestions when we're in a bit of trouble. Thanks to all who responded. Quote
Members AngieNZ Posted May 16, 2019 Members Report Posted May 16, 2019 On 5/16/2019 at 5:34 PM, LyndHoll said: Yep. It's a knee lever, so not hard to remember that. Expand I had this problem and its easy to do Make sure you arent unintensionally pressing your knee against the lifter as it will do just that if the slightest touch there.I know cause I did .otherwise like others said tension check till right Quote
