Members coma44 Posted May 25, 2019 Members Report Posted May 25, 2019 I found a drafting board on Facebook market place for 100 bucks. It was in great shape and all there. It is a full "e" drawing size board so it is 38" x 50" think I will add a plastic top that is removable so it can de dual purpose. Patterns and cutting table just by adding the cutting board. Quote
kgg Posted May 25, 2019 Report Posted May 25, 2019 You should get some good use from that surface area. Very nice, the drafting table brings back some good memories from my previous life. Now you well be able to get the angles correct easier every time when marking / cutting. Does the table have the ability to move from almost straight up to down flat? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members dikman Posted May 25, 2019 Members Report Posted May 25, 2019 Great idea (as long as you've got the room for it!). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members coma44 Posted May 25, 2019 Author Members Report Posted May 25, 2019 On 5/25/2019 at 7:40 PM, kgg said: You should get some good use from that surface area. Very nice, the drafting table brings back some good memories from my previous life. Now you well be able to get the angles correct easier every time when marking / cutting. Does the table have the ability to move from almost straight up to down flat? kgg Expand I took 3 semesters of drafting in high school two of architectural and one mechanical. Used boards like this one the last year. We only had a few of them though. So had to do it the old way most of the time. I was a mechanical designer for 8 years and used CAD on the computer to for everything. It is nice to get back to basics On 5/25/2019 at 10:31 PM, dikman said: Great idea (as long as you've got the room for it!). Expand I don't have a ton more space that I can use for leather work right now so the space saving of making the table dual purpose will help in the long run. Quote
kgg Posted May 26, 2019 Report Posted May 26, 2019 Ya the good old days, I use to design & build substations and sequential controls for about 25 years. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
MikeRock Posted May 26, 2019 Report Posted May 26, 2019 Cool thing is you can remove the vertical arm by just loosening one lock nut and backing out the pointy screw. Downside is the top is springy for mallet work unless you lower it all the way and have stacks of old magazines under the table to help absorb shock. Been there, computer is sitting on it as I type. Good deal on that table and drafting unit. Mine is a K&E from 1969. Quote
Members coma44 Posted May 26, 2019 Author Members Report Posted May 26, 2019 On 5/26/2019 at 12:48 AM, MikeRock said: Cool thing is you can remove the vertical arm by just loosening one lock nut and backing out the pointy screw. Downside is the top is springy for mallet work unless you lower it all the way and have stacks of old magazines under the table to help absorb shock. Been there, computer is sitting on it as I type. Good deal on that table and drafting unit. Mine is a K&E from 1969. Expand Exactly my plan. Save space and keep costs down for now. Use the savings to fund more projects and practice pieces. Quote
