bikermutt07 Posted August 3, 2019 Report Posted August 3, 2019 14 hours ago, mikesc said: Ah.. that is OK then.. I have to confess I had a "temporary belt" ( bungee cord ) on one machine for 6 months! Red Green says, "remember folks, this is only temporary...........unless it works". Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members Pterytus Posted August 4, 2019 Members Report Posted August 4, 2019 Hey guys, (Ok, I confess: It was me ;-) It's a Ø4cm/Ø13cm part ordered from Sieck here in Gemany http://www.sieck.de/maschinen/naehmaschinen/schuh-schaft-herstellung/diverse-naehmaschinen/?produkt=9237 But you can get the same device at http://www.cowboysew.com/product911.htm or https://www.allbrands.com/products/39722-techsew-sr-speed-reducer-slows-down-handwheel-rpm (prices DO vary...) I used the leather belts just because they were easy to make at that moment and I could tweak the length so I would know which exact length of V-belts to order. In the pictures you can see the parts I used and the installed carrier without the speedreducer mounted. The star shaped head screw and modified hex nut are optional, a standard bolt and nut do the job, you then just need tools to tighten. Cheers, Pete... Quote
Uwe Posted August 4, 2019 Report Posted August 4, 2019 5 hours ago, Pterytus said: Hey guys, (Ok, I confess: It was me ;-) Thank you for inventing this elegant and simple mounting solution and sharing the details with us. Thanks also for the sourcing links - interesting that the identical part is available in Germany for a mere third of what vendors here in North America charge. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members Pintodeluxe Posted August 4, 2019 Members Report Posted August 4, 2019 This looks like a great idea. I had that style of speed reducer mounted to the table, but I didn't like it because I couldn't tip the machine head back. This should solve that issue. I went with a box type speed reducer, which works great too. This is a very clever idea you came up with. Nice work. Quote
Members Pterytus Posted August 4, 2019 Members Report Posted August 4, 2019 Dang! Should've patented it first, then... ;-D No, really: Thank you guys for your kind words and I'm glad if you like and/or use it for your own setup (As in: Why is there so little space under such a big table?). Cheers, Pete... Quote
RockyAussie Posted August 5, 2019 Report Posted August 5, 2019 6 hours ago, Pterytus said: Dang! Should've patented it first, then... ;-D No, really: Thank you guys for your kind words and I'm glad if you like and/or use it for your own setup (As in: Why is there so little space under such a big table?). Cheers, Pete... Great thinking....Hang around some @Pterytus I love to see more of this type of thinking. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Constabulary Posted August 5, 2019 Author Members Report Posted August 5, 2019 21 hours ago, Pterytus said: Hey guys, (Ok, I confess: It was me ;-) There he is - the inventor Thanks for jumping in here and sharing more details. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Pterytus Posted August 5, 2019 Members Report Posted August 5, 2019 Yeah, I think I'm going to make it a Habit: Decent idea - once a decade - sounds like a plan! ;-) Cheers, Pete... Quote
