HI,
I restored an old Singer walking foot machine.  I just found a free IKEA desk/table on CL that will enable me to mount the motor underneath.     Do I want the machine mounted  to the right so material being worked on can sit on the table??  Whats a good working distance the machine should be from the front edge??
I have to cut a hole for the machine and also for the belt
THANKS for any input!
I don't think there is a set rule if your going to make your own table-top.  You just have to make sure it all lines up from the bottom to the top, so the motor and belt are not in the way of the table legs, plus it is heavy and you don't want it to lopsided so it tips over.   They are typically offset to the right like in your picture to give you a little more room on the side for the project to float around as your sewing, and still access to reach the hand wheel.  Looks like a nice table top.
One day I hope to learn how to sew.....
Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
As long as that table ( top is thick enough ? )  for an inlet. That is great working size top .
Also you need check-look and mark on top-side where the underside metal table frame is located before commit cutting . also make sure your belt-cut-out and if running reduction wheel ? it has room on underside from hitting frame .
IF it were me ..  because of large size top .. I would keep it about where it is and make an set-in cut for where operator sits . So you get a little more L-side for materials to hang on the larger size patterns you stitching .
' Roughly ' . I marked with Line in Pic. for Cut Out where you Sit .
Also where I marked  ( D. L. ) .  It EASY to hinge a Drop-Leaf that can swing-Up an lock for even more top when needed , and then just swing down and out way when not needed .
Edited by nylonRigging
-You could also glue 1/2 inch plywood to bottom, but I would "think" hard about using it though because of the single -middle side legs- 4 corners would be much better.
You might need to add some braces to the table legs to make the table more stable when in use. I am guessing the table top is 3/4" thick? Add a piece of 3/4" plywood to the bottom. Don't cut out the corners on the plywood so the machine can rest on it. Here is a link to a post on here with dimensions for the cutout.
https://leatherworker.net/forum/topic/73515-table-top-template-for-singer-211-class/
Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S,  Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
what (  JJN  ) says . you needs to be ( 1.5" )  thick .
easy to laminate and add to it . Just  'Glue and Screw'  cordless driver or use Air-gun staple to be fast . I used commercial gun last time I did this and was great . Don't run screws or staple/nail in the Cut-Out spot where you got to cut .
you need to do it on a flat patio outside or flat inside concrete floor . just get good Plywood, Dont get crappy plugged finish plywood . You can use the particle board, but Ply. is better for not getting a Bow on the top over the long run years latter . Just Cut Ply. same size as top . glue and walk along with your body weigh and Screw it all down . Then go back in half hour and wipe all the excess glue that will press out the edges with wet sponge . leave sit for few days to cure .
If you're not planning on a speed reducer/motor setup you can skip the belt cutout and do a motor mounted topside behind.  I agree on the suggested thickness, i made this table from melamine and at one layer it would sag with my little singer 66k so an industrial machine definitely needs the reinforcement.  I used the same material and did two layers of melamine, The hole on the top was cut to fit the shape of the bed, the hole on the 2d layer was cut to allow openings for mechanisms and keep a lip and corners which have a spacer for the machine to sit on and flush with table.  For the motor control, i unmounted from the bracket and mounted to the bottom of the table to line up with the pedal assy.
Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
THANKS for the reply and photos!
iI just cut the hole for the belt which took some support from the under layer.  To be honest I had not thought of mounting the motor up top and had not see it, but my motor is old and ugly and vey "homemade" looking so its better hidden :huh:.
Interesting that you mounted leaving more table in front?
