You bought 2 pairs of sole presses. There are usually more pieces. You would place the other pieces in the shoe and screw the handle down and it applies pressure to the sole while the cement sets. The second picture is a riveter. And the final item is an American 3-in-1. It's used to cut and skive leather.
@BruceEW Please post the photos here.  If the photos on imgur are moved, deleted, permissions changed, etc., then this post becomes useless.  As you work your way through older posts here, you will find many broken links.  We would like to keep these posts/threads intact for the future.
Tom
The day will come when imgur will close down or begin charging to host images..tinypix is closing their service in September 2019..Many other image hosting services are gone, which is why many threads here are missing images, always post images here..Tom posted while I was typing :) Here is the image  that was posted to imgur.
You took them on an iphone..( the original image data size was 1.9 megs, ) to make them smaller, email them to yourself.
HTH :)
Edited by mikesc
The picture #2 is a snap and rivet press. Made in Turkey. If you'd screw it to a piece of 2x4 it would be a portable press :) All you need is dies which can ring you a hefty bill being $40-80 a set.
I missed #2 at imgur..
The press takes standard die sets for punching holes and setting snaps, rivets, and eyelets. This is a much better design than the cam/lever press you see on ebay and aliexpress. Those are designed for foot operation while this is the truly hand operated press. This one costs $60-70 new.
Edited by DrmCa
  On 8/20/2019 at 9:59 PM, Sturme said:
you might be able to modify a pair of lasts to make the show presses functional, just a thought
Expand
Would there be a benefit to using these instead of just hammering down contact cement?
Also, what exactly is the American 340 useful for?
Expand
in affect you would be creating a press, so you could clamp the shoes down under pressure for hours till the glue completely dries and sets.
  On 8/27/2019 at 12:14 PM, BruceEW said:
Anybody got any thing to say about the American 340?
Expand
It's a 3-in-1. The side blade is used to cut and trim materials and the top is used to skive.
