On 1/1/2021 at 10:53 AM, maxdaddy said:
Gray, I've long admired your work. Can you describe how the laser is used in your belts and strap projects?
I burn the uploaded artwork directly onto the leather. You can dial in and get so much more detail with the leather. The above fish scroll is a tad over an inch in height. You could never get scrolls that small with a swivel knife. Then bevel. I used to cut the art edges with a swivel knife, but it’s not necessary. It’s easy to bevel off of the laser burn.
The artwork takes the most time. The laser is only as good as the artwork you are printing. You can upload any number of designs/images from the internet- some with photo like real ness. I once did a black and white photo of Hank Williams and the shading was perfect. Looked like the photo. Once the artwork is in the Glowforge system, you can just hit print again as many times as desired. Or resize it to a wider belt. Everything else before was just a one off. I never used stencils I just cut and drew onto the leather. I still do some “old school” carving. It took me a long time to self teach myself the Krita art software. That was a slow learning curve.
All in all, the laser is a great tool for the artist/leatherworker. A paintbrush in the hand of a novice won’t produce a masterpiece.
  • Replies 26
  • Created
  • Last Reply
Top Posters In This Topic
You've obviously done a great job of integrating it into your workflow. Thanks for the details.
Will the Glowforge also burn the stitching holes?
I've had a Cricut Maker for about a year and I should probably start working it into my projects using a similar approach. I'll need to 'outgrow' the Cricut before I can justify the expense of a Glowforge.
I dunno, I think it’s apples to oranges - but I don’t own a laser. I’ve found a variety of leather uses for my Cricut but it’s limited in ways a laser just isn’t. Wish I could rent a glowforge for a month to see what I could and couldn’t do with it.
Try a local makerspace. That’s where I use(d) one in the before time... long long ago (pre-covid)
Yes, I’ve considered this in the past but just can’t justify the cost for my local one unless I could quit work for a month and basically live there.
That sucks. Mine is $25/mo no commitment
I’d do that in a heartbeat. I believe mine is somewhere around $150/mo and most of the cool equipment requires a paid class before use. I was excited when I toured the place but it’s just not realistic for me.
I did not buy a GlowForge. They are highly advertised and look nice but I didn't wish to have to go through a company to get anything I want to use for additional money. That said: I bought a 3000Mw diode laser to practice on.
Sufficient for that purpose, biggest problem is the low power and they are very slow. Dove into the big boys. Orion 60W CO2, Chinese Laser. With the crate it had a delivery weight of 400#. It is a floor model.
Out of the crate it worked perfectly and has continued to do so. I simply could not afford an American made with nearly the same specs. I use LightBurn software and wouldn't be without it. Also use Adobe Illustrator and Photoshop. Have a daughter who is a professional graphic artist. I intend to do some leather engraving, have been so busy with other items I haven't had time. My laser will do leather, wood, glass, anodized aluminum, cork, fabric, plastic, ceramic tile, marble, etc. Enclosing pics of a couple items I have made.
Second one is on 1/4" Baltic Birch, first, is a vintage photo on 3/4" Hickory
Ferg
Edited by Ferg
DAMN son! I had to do an orientation for the Glowforge but it was free.
All of this being said one day when I can afford one I'm leaning toward the Dremel DigiLab. I don't want my laser to stop working one day because GF goes out of business. I know the overseas ones are just as good but I've gotten burned on an industrial sewing machine like that. Its a Juki clone and its just too much tweaking for me. For someone used to these machines I have no doubt it would be great. Wish I could sell it and I might try to.
I'm gonna go and do what the op didn't want. But please don't get a glowforge . Please go find someone that has a Rabbit or a Boss or a Thunder laser. You can buy one here in the USA  for about the same price as a glo pro and its going to be 10 times the machine. Have good support and doesn't depend on the internet to work.Someone asked it it would cut the stitching holes. You can program in corel to put the holes in. You make them the size you want and space them at what you want and the laser cuts them out. Not sure if you can do it with a glowforge.
