CowboyBob Posted September 26, 2019 Report Posted September 26, 2019 You can start with a pin 7/16" or 11mm long,it's might be alittle longer than what you need BUT you can always grind it off or bend the release bracket on the backside of the tension. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members vonL Posted September 30, 2019 Author Members Report Posted September 30, 2019 Hi folks ! Thanks for the advice! Will try some of the tricks mentioned. Working hard right now to get my workplace Nice and tidy with some new paint and shelves. Really looking forward to get a Nice place and a servomotor, and get going. I've seen some nice deals on the enduropro motors. 220v. Are they any good? Quote
Members vonL Posted October 18, 2019 Author Members Report Posted October 18, 2019 I've been reading alot on the web about old clutch motors and how incontrollable they seem to be. Also, the look of the motor on my table didnot add much to my confidence, being an ancient 110v 3phase converted to 220v 2 phase, full of dust and filth. I was sure buying a new servo motor was a must. I havent even tried to start the old clutch motor. To be honest, I was afraid it would either give me a huge ZAP!, blow a fuse or catch fire, while sounding like a jetplane indoors. That was until today. I figured I might aswell jump feet first, ignoring the thoughts of a possible hazardous outcome. Boy was i wrong! I flick'ed the switch (what a Nice switch btw, an originial singer all-metal switch with a really pronounced 'click') and the motor started right up, no problems! It has the typical clutch motor sound (I actually like the sound - for now). And it is really not that incontrollable, I'm sure it will be even easier to controll if I change the pulleys. Next step is aquiring some thread and let it rip:-) I have some schmetz 21 dp leather needles (came with the machine), am going for size 92 thread to try out. I need to clean the stitch length mechanism, as it won't change length. When I engage the left button, I can hear a slight "twang" inside the machine, but no movement in the length selection mechanism Quote
Members vonL Posted October 18, 2019 Author Members Report Posted October 18, 2019 Oh - and the "chug-a-chug-a" of the walking foot is just NICE! :-) Quote
480volt Posted October 19, 2019 Report Posted October 19, 2019 This is totally academic since the motor runs, but could you post a picture of the motor rating plate? I suspect it’s a single-phase, dual voltage motor. You can’t change a motor from 3-phase to single-phase, and actual 2-phase power is extremely rare and requires purpose built motors to use it. Also, is it grounded (earthed)? Quote
Members vonL Posted December 4, 2019 Author Members Report Posted December 4, 2019 Hi ! It's been a while since I checked in, but 480volt - Yes, You are right - it is of course not dual phase, but 3 phase, with a huge white something into which the wires go, and this something lets the motor run on 220v single-phase (presumably?). Anyways, It is an old lump, singer 1/3hp 1425 rpm. Will have to do for a while until I can afford a servo-motor. I am in need of some advice, please let me know if I'm posting in the wrong forum. I will be using my 111w155 for both leather and fabric, ranging from light upholstery leather up to double layers of 4-6 oz chrome and/or veg tanned leather (Purses, totebags, motorcycleseats, etc), and all sorts of items in canvas and denim and other heavy fabric. I've read that the 111w155 will work with thread in the range of 69-138. I am having a hard time figuring out what sort of needles i should buy. If I was to buy 1 spool of all three thread thicknesses, and needles accordingly - which needles will I have to buy? The more i read and surf the web, the more confusing it gets:-/ Quote
Members vonL Posted December 5, 2019 Author Members Report Posted December 5, 2019 Btw I know which size of needle recommended, what I can't really find an answer to is needlesystem, tip/point and all that. Seems to be lots of different designations? (Let me know if my spelling is bad:-)) Quote
Members shoepatcher Posted December 5, 2019 Members Report Posted December 5, 2019 System is the specs to that actual needle. in your case 135x17 for round point, 135 x 16 for leather point. Size is either Singer number such as 23 or metric which for a size 23 would be160., 24/180, 22/160, etc. Leather tips tri is triangle point, Dia. is diamond point, RT is a reverse twist, LT is a left twist,, etc. So system first, type of needle second, size third. Hope that helps. Most sewing machines designed around a particular needle system. glenn Quote
Moderator Wizcrafts Posted December 5, 2019 Moderator Report Posted December 5, 2019 20 hours ago, vonL said: I've read that the 111w155 will work with thread in the range of 69-138. I am having a hard time figuring out what sort of needles i should buy. The Singer 111w155 uses the very common System 135x16 (leather point) and 135x17 (round point) needles. Leather points come in various shapes with the most common being a left twist slicing point, a triangle point and a diamond shaped point. Needles are available in packs of 10 and are relatively cheap. You can buy a pack of each point in one "size" until you decide which you like best, then stock up on those in all sizes you'll need. Here is a thread and needle chart to help match needles and thread sizes. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members vonL Posted December 5, 2019 Author Members Report Posted December 5, 2019 Aha! Great info - thanks guys:-) so I should be using 135x16 for leather (with it's various points) and 135x17 for fabric? Quote
