Members Hildebrand Posted October 11, 2019 Members Report Posted October 11, 2019 (edited) Here are a couple pictures of my latest holster, this one is for a friend who wanted to be able to take it off his belt without undoing the whole belt since he is left handed so I used 3 snaps instead of sewing the loop. Things are finally coming together. I learn something with each build. This one taught me to use contact cement not rubber cement for my edges, couldn't figure out why I always had a slight gap after gluing, sewing and sanding. Turns out the rubber cement was thick enough to notice. The die is supposed to be Fieblings Saddle Tan but I think my applicator must have gotten used for a darker die and put in the wrong bag, this is way darker than Saddle Tan. As always comments and criticism welcome. Todd Edited October 11, 2019 by Hildebrand more info asked Quote
Members chiefjason Posted October 11, 2019 Members Report Posted October 11, 2019 Looks good. Did you oil it any? Oil can really darken saddle tan. Quote
Members Hildebrand Posted October 11, 2019 Author Members Report Posted October 11, 2019 I did oil it but it was dark before I oiled. I am pretty sure I screwed up with my die applicator. Todd Quote
Members SLP Posted October 12, 2019 Members Report Posted October 12, 2019 Was the saddle tan the Pro Dye? I usually cut the Pro Dye with denatured alcohol 7:1 alcohol:dye. I know it sounds like a very dilute mixture, but it works to keep the tan color very true to saddle tan. It does require several coats, but does not get too dark. I've heard some say to cut the Pro Dye a minimum of 1:1 as a matter if course. Nice work, by the way. Quote
wizard of tragacanth Posted October 12, 2019 Report Posted October 12, 2019 (edited) Very nice work. Those layers do look nice and clean. What brand of contact cement did you use? nick Edited October 12, 2019 by wizard of tragacanth Quote Nick
Members Hildebrand Posted October 14, 2019 Author Members Report Posted October 14, 2019 I use the Renia Aquilim. I really like it since I can use it in the house. @SLP it is the pro die, I am pretty sure it was my operator error that caused the color to be off. Worst part is dad saw this holster and thinks he may want one that color. Todd Quote
Members Hildebrand Posted October 15, 2019 Author Members Report Posted October 15, 2019 Update, I delivered this holster to my friend last night. The 3 snaps to hold the belt loop is a fail. The loop keeps constant pull on the snaps to open so any little pull lets them come open. I should have used the pull the dot snaps but didn't because I thought trying to get it to snap or unsnap off the belt would be to cumbersome with the directional snap. Just wanted to put this out there incase someone else was thinking of doing one this way so you could avoid my mistake. Todd Quote
wizard of tragacanth Posted October 15, 2019 Report Posted October 15, 2019 Thanks for sharing this info. This is sad news. I wondered how they would work out. They sure look nice. Do you think pull-the-dot snaps are the solution? Are you going to try them? To the best of my memory, it seems that when snaps are used, they always loop over, and around, then snap on the front. I really liked the looks of the design, sorry it didn't work out. Let us know what you do with this. nick Quote Nick
Members Hildebrand Posted October 15, 2019 Author Members Report Posted October 15, 2019 Wizard, I am not sure what route I am going to take, the backs of the snaps are embedded as this is a lined holster so any replacements would be exposed. I may try to drill the snaps out then replace them with pull the dot snaps with plastic covers on the inside. It also may be chalked up as a lesson learned and a replacement constructed. Todd Quote
Members dikman Posted October 15, 2019 Members Report Posted October 15, 2019 It's called experience, and we all learn from it. The idea was good, just didn't work so well in reality (unfortunately). I made a copy of the holster used by Steve McQueen in The Magnificent Seven, which has a similar style of loop but I used Chicago screws to secure the flap. Glad I didn't try snaps or I would probably have had the same issue! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
