Members Pappys Leather Posted November 21, 2019 Members Report Posted November 21, 2019 Anybody here using a 12 ton press to emboss leather? How do you know how much pressure to apply and how do you make sure you can apply that pressure ever time? Quote
Members Carnivore Posted November 21, 2019 Members Report Posted November 21, 2019 I would think you should be very careful using a 12 ton press to emboss leather. Instead of embossing it could act like a clicker press and cut right through. Quote
Members BigSiouxSaddlery Posted November 21, 2019 Members Report Posted November 21, 2019 (edited) It depends on the embossing plates and the leather. I use a 20T press all the time to emboss box loops for harness, using brass embossing dies. I have cut right through the leather before, although it was more of a crushing than cutting action. Typically, if you use good solid leather, this won't happen. But a deep embossing die with thin leather, watch the pressure. Edited November 21, 2019 by BigSiouxSaddlery Quote
Contributing Member JLSleather Posted November 21, 2019 Contributing Member Report Posted November 21, 2019 what does your press look like? probably a simple fix if you have the "shop press" type thing used for bearings 'n' such Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Rockoboy Posted November 22, 2019 Report Posted November 22, 2019 23 hours ago, PappysLeather said: how do you make sure you can apply that pressure ever time? My shop press has a gauge to indicate the pressure, but I guess not all shop presses have that option. Maybe, once you have done the 1st item that you are happy with, you can copy by counting how many pumps of the handle. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members Pappys Leather Posted November 22, 2019 Author Members Report Posted November 22, 2019 Been trying that guess I haven't found the right amount. Struggling with how wet to get the leather. Here is wht I am working with Quote
Rockoboy Posted November 22, 2019 Report Posted November 22, 2019 Your leather looks too wet to me. You appear to have a halo of excess moisture around the stamp. The leather should be almost the same colour as dry leather, but cool to the touch. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
wizard of tragacanth Posted November 22, 2019 Report Posted November 22, 2019 If you are just doing small stamps like the one that you are showing, it may be safer (more controllable) and easier to use an arbor press for that. https://www.harborfreight.com/1-ton-arbor-press-3552.html nick Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
Contributing Member JLSleather Posted November 22, 2019 Contributing Member Report Posted November 22, 2019 1 hour ago, wizard of tragacanth said: If you are just doing small stamps like the one that you are showing, it may be safer (more controllable) and easier to use an arbor press for that. https://www.harborfreight.com/1-ton-arbor-press-3552.html nick or a mallet Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
toxo Posted November 22, 2019 Report Posted November 22, 2019 Or, depending on where it is, a G clamp. Quote
