  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
12 hours ago, Bert51 said:
On the subject of tensions, whether Bobbin or Top Thread it does not matter, you have to work out what works for you, for your machine and what your sewing. You use very little tension on thin leather and heavy tension on thick leather.
There is some very helpful post here to guide you to find your ideal tension for this project, hewre is a link to what I found helpful information from one Aussie. Say no more, but the whole thread makes good reading,
Yes, I think you always need to test on test pieces of real fabric or leather to adjust your tensions to the result you want. However, when you have used your machine for something else, and you go back to the same kind of work again, you can limit your amount of trials by using an instrument to set your tensions.
I did read your refered thread about tensions and results and i just read it fast again. I think it covers many interesting subjects, and many issues of mostly top thread tension. I believe that the bobbin tension in most cases do not vary that much. However the top tension can vary a lot due to how heavy the fabric you are sewing and your aim at getting a ballanced stitch.
14 hours ago, kgg said:
but do the bobbin drop test, adjust bobbin tension as needed and do a test stitch
The weight of the filled bobbin and bobbin case of my class 15 type is about 0.18 N. So a drop test ensures a force somewhat above this value - typically 0.25 N for me. The weight of a larger bobbin case and bobbin will of cause increase this value. When you try to measure the tension by holding a boobin case by hand and pull the thread of by the dynamometer, I can get rather big variations in figures. The force is dependent of the direction of your pull from the bobbin case and if you tuch the rolling bobbin.
In my expierience, you get more dependable tension figures by measuring the thread tension of the bobbin thread comming up through the needle plate. For some machines it is hard to remove the bobbin case, and then you need to use this method anyway. I have not seen any significant difference in bobbin tension from a near empty bobbin and a near filled bobbin. I do not use bonded thread, and I get your point, that the coil memory in bonded thread have issues.
I do not want to make this a physics class, so I will just say that the weight of 1 Pound on the earths surface is 4.45 Newton [N].
Really - NM for bobbin cases? There is always someone who needs numbers for everything. Bobbin tension is no science and no one needs a table for this - there is just a freaking screw - turn it back and forth - done! Even as a novice it took me just e few trials to figure out how top and bottom tension works. its explained in all manuals I recall - even with pictures. Bottom tension as low as possible the rest is top tension and if you need a tighter stitch increase both by a 1/4 turn at a time until the know is balanced - done. You have to try it anyway so what is a NM number good for?
The Husqvarna 2000 series domestic machines were adjusted for 22 grams tension on the bobbin thread from factory. (Just for reference, not machines for leather obviously.) The pattern cams for those machines happens to weigh about 22 grams, so the manual suggest using one of those hanging from the thread to rough adjust the bobbin tension. A simple method anyone can use without any special tools, just find a suitable weight. 100g = 1N.
Thanks for this reference. I got another reference that recommend 21 gram-force. I think most domestic machines use a V23 thread for garment. I tried to measure the force from a bobbin case a similar way using a digital kitchen scale, where I look for the weight loss on the scale:
617479552_kitchenscaleforbobbinthreadtension2.thumb.jpg.a1016f8aabd11577366a54b9121f702d.jpg
However I do see some variation in the measurement depending on how I hold the bobbin case. With some care I think this kind of measurement is useable. Many households got a digital kitchen weight today. But it seems to me that measurement by a spring dynamometer on the thread from the needle plate is a more accurate measurement.
I do not agree, that a spring dynamometer is a special tool. It is not that commen in a home, but most people have used them in primary school, and they are cheep and easy to understand and fast to use.
Thanks for your comment, Constabulary. I like to get some opposition, and it helps to bring forward a good debate and arguments. In my view it is very fast to use a spring dynamometer and bring back the tensions to a privious desided tension. When I do the test sewing, it will normally be spot on again. Without use of the dynamometer I would typically need 5 tests and itterations by test sewing. So I think the use of the dynamometer is a faster way. And yes I like numbers :)
PS: My mother had a Husqvarna 2000, and I learned to sew on it as a child, but I did not know this about the cams.
An interesting exercise but I agree with Constabulary on this one. We have to be careful not to over-think things sometimes.:)
Contraire -- what what works for some folks might not work for other folks. The OP seems to offer a repeatable solution for varying situations.that might appeal to some users.
It's "au contraire", to be precise ;) and yes, your are right, of course, but I think it's safe to say that most on here who use industrial sewing machines soon learn how to judge bobbin tension and also, in most cases, tend to leave the bobbin alone and tweak the upper tension when adjustment is needed. Except in dire cases.
This is precisely what I just did with my Chinese patcher. I could not get it to sew consistently and eventually backed the bobbin tension right off and use the upper feed to balance the stitching. That finally worked.
Well, now people that like to share these bobbin tension values can do it.
I use these spring dynamometers, and I think the most significant benefits have been to diagnose tension problems faster and fix them. It it is much faster than a lot of test sewing. I have had problems with tensioners giving variation in tension including once with a shuttle tensioner. When you search this forum and look for problems with tension or helpers suggesting wrong tension - I think you get over 1000 posts.
  • 1 year later...
Has anyone used a TOWA bobbin gauge?  Pretty slick.  I have a longarm quilting machine (in addition to my other machines, one of which is a Consew 206rb5) and it is helpful, as I change types and weights all the time.  I was looking for gauge settings recommended for my Consew but all I can find is the drop test, of which I have found at least three ways to do it.  I have just been working on moosehide slippers and have been fighting the tension which feels really tight.  Being a retired physician, I like precision - reproducible numbers rather than hammers or "it just feels right".  I was hoping that someone might have a suggestion for a starting point for an industrial walking-foot machine sewing leather???  It appears to be very different than for my longarm.
