Hi there,
Have you ever seen something like this? When I saw it I though that it is made by dipping leather into into a water-dye substance. Author of this technique disclaimes that. What do you think? I have few other hypothesis about how to do that. I need to do some tests with other types of dyes.
https://www.partahama.cz/technika-tahama/
Hi arcrue
That looks somewhat like some videos I've seen on a process called marbling, try searching here or youtube for marbling or marbled leather.
Mark
Corter leather has a video on a tie dye wallet . Using water and oil dye . I have tried it and it does work, but it has a steep learning curve to get it right. I have done it three times and have adjusted the ratio of water to dye and still need to keep adjusting the dye content. It uses a boat load of dye I don't know why the video calls it tie dye , it definitely is a marble effect..
Are you using the water thickener Carrageenan and painting the leather with Alum before starting. That seems to be the best way so i understand
Mi omputer is ot ood at speeling , it's not me
I just followed the video using water and Fiebing pro oil dye. But thanks for the info, I will have to try it out and see what happens.
  • 1 month later...
mdawsonthank you! I didn't know the term.
rleather: I knew that before. I tried that and I agree that learning curve is like you said. I know that the author (He calls himself author of this technique...) doesn't use oil dye, but alcohol or acrilic. I know his supplier.
There is my first result with alcohol dye...
Guys thanks for answers. I see that this is known technique if you know sources :)
Edited by arcrue
