I used M5 screws on my former Singer 111 but you may need an additional bracket for mounting the drop down guide. I have used KB09 from college sewing:
https://www.college-sewing.co.uk/accessories/sewing-guides/sewing-guide-brackets
This was on my former 111G156 which is quite close to your 239
So before you drill holes in the machine body make sure the drop down guide or its bracket is not disturbing your foot lift lever or is disturbing you somehow different. On my current 111 I have no drop down guide as I figured I barely need it for my work or it was disturbing me. But that of corse depends on your work. ;)
EDIT:
Another thread reg. drop down guides:
Edited by Constabulary
Thanks Folker. You came through as always. I can see where there might be a problem and I'll get a bracket ordered today. At least I'll know what screws to drill for when they get here. Like Mike I've often wondered about the virtues of roller versus flat guides. I'm reasoning that if I need a flat I can just use some magnets.
Looks like that COMES WITH bolts.
5 leather patterns
Yep, the big question is - what is the thread size of those bolts?
I have some thread guides once they get here.
That's good, because one of the joys of metric threads is the vast number of pitches they use!! Can be very frustrating.
It'll probably work out that I'll find a couple of screws that fit whatever tap I can find.
Update. For future information the bolts are M6x1 and takes a 5mm drill for the tap. I got over the siting problem by cutting the end of the bolt hole to the right just enough so the presser lift is clear. I ran into a slight snag when drilling the left hand hole. I got part way in when the drill snagged. put a torch on it and it looked like hole in the casting. Was deep enough for the tap so was ok. Was a bit fiddly but all working as it should.1534424155_IMG_E23861.thumb.JPG.d4156fa3e896409c909739624223ae8f.JPG
Edited by toxo
