Hi Everyone,
I'm looking for material suitable for use as as lining for wallets or handbags.  Possibly nylon, but in some applications I would like to bond it directly to the flesh side.
Thanks for your help
Silverd
Use silk. Readily available for lining clothes. Bond it with iron on heat activated sheets of adhesive. Forgot what thats called. I'll add it later if I remember or someone else will name it.
The term might be fusible interfacing or fusible web.  Heat n Bond (sp?) is one brand.
That is a fantastic idea.  I definitely will try your suggestion!
Many thanks
.Silverd
Does silk come in different gauges or thicknesses?  I'm out today to my local Joan's today.
Silverd
It does.  It also comes in different textures.  I doubt JoAnns is going to have a broad selection of silk.  The ones I've been in up here stock mostly cotton for quilting or fleece with a small selection of other materials.  You might find a better source in/around LA or online.
Understand.
Do you make a lot of wallets and bags?
Silverd
Edited by Silverd
Add image
  • CFM
1 hour ago, Silverd said:
Understand.
Silverd
Shewing my ignorance, but what tools are those? I know the cobbler's hammer and the dividers, but I have never seen the other two. :huh:
4 hours ago, Silverd said:
Understand.
Silverd
No, but I sew.
You might ask to see what they having for suit lining material.  You can cut synthetics with with a hot knife to stop the edges from fraying.
The one to the right is called a straight Channeler which I purchased from Bruce Johnson.   I don't use it for wallet making but I do when making traditional English Throat Latch Rounds for equestrian  halters and/or round reins.  It cuts a slit or channel in the U shaped section of the strap after it has been pulled through a rein breaker.  Two slits are cut one on each side of the U section, then a stitch is sewn through them that holds the round together. I sew though the channels using a Claes 30 Patcher but have purchased a Landis 16 to do this work in the future.  Landis actually made a rein rounder attachment which I hope to aquire soon. Person also made one as well as others.  A difficult process but one that yields a nice looking latch or reins.
The other tool is also a Channeler but the blade is set at an angle.  Great turn of the centry tools that still work today!  Both tools are included in the photo to evoke a sense of traditionally made products...which is how I make my stuff for the most part!
Edited by Silverd
Word spell
