Members JeannieH Posted February 13, 2020 Author Members Report Posted February 13, 2020 On 2/12/2020 at 5:01 AM, jimi said: Hi, Yes that looks like it will fit. You just need the binder and the inside foot. did you see if you could lift your foot up a little? It should be the wing nut over at the back at the end of the bar for adjusting? Hi. I don’t have a wing nut in the spot you mentioned. My outside foot does come up quite a bit more than the inner foot. Which of these nuts do I loosen to adjust the height of the inner foot? First or second picture? Quote
Members dikman Posted February 13, 2020 Members Report Posted February 13, 2020 (edited) Jeannie, have you downloaded the manual I linked? It explains how to adjust the feet. The wingnut should be on the other end of the bolt in the first picture, it tightens a curved slotted bar. Edited February 13, 2020 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members jimi Posted February 13, 2020 Members Report Posted February 13, 2020 (edited) 3 hours ago, JeannieH said: Hi. I don’t have a wing nut in the spot you mentioned. My outside foot does come up quite a bit more than the inner foot. Which of these nuts do I loosen to adjust the height of the inner foot? First or second picture? Hi Jeannie, sorry for taking so long in getting back..... the first picture. Edited February 13, 2020 by jimi Quote
Members JeannieH Posted February 13, 2020 Author Members Report Posted February 13, 2020 4 minutes ago, jimi said: Hi Jeannie, sorry for taking so long in getting back..... the first picture. No problem I had figured it out not long after I sent the message. Thanks anyway 40 minutes ago, dikman said: Jeannie, have you downloaded the manual I linked? It explains how to adjust the feet. The wingnut should be on the other end of the bolt in the first picture, it tightens a curved slotted bar. Yes I printed one out. But I don’t have a wing it for some reason. I did get the feet adjusted though. Quote
Members jimi Posted February 13, 2020 Members Report Posted February 13, 2020 does it feed better then?? Quote
Members JeannieH Posted February 13, 2020 Author Members Report Posted February 13, 2020 16 minutes ago, jimi said: does it feed better then?? Way better and I got my cheap binder to work. Just had to mount my binder on the bracket it came with in the wrong position to get that metal guide out the way. Quote
Members jimi Posted February 13, 2020 Members Report Posted February 13, 2020 2 minutes ago, JeannieH said: Way better and I got my cheap binder to work. Just had to mount my binder on the bracket it came with in the wrong position to get that metal guide out the way. Well done jeannie, yur gettin there. Quote
Members JeannieH Posted February 13, 2020 Author Members Report Posted February 13, 2020 40 minutes ago, jimi said: Well done jeannie, yur gettin there. Thanks! Now I have to learn how to use it efficiently. I will post my bag after it’s made(waiting on my lagun leather from Carriat). Quote
Members dikman Posted February 14, 2020 Members Report Posted February 14, 2020 (edited) Way to go, Jeannie! Looks like it's sewing well. I look forward to seeing the end product. Edited February 14, 2020 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members JeannieH Posted February 14, 2020 Author Members Report Posted February 14, 2020 2 hours ago, dikman said: Way to go, Jeannie! Looks like it's sewing well. I look forward to seeing the end product. Thank you! Me too lmbo! Quote
