Members RoosterShooter Posted April 3, 2020 Members Report Posted April 3, 2020 I have a 2 month old Cobra Class 4 that is skipping stitches every 30" to 31" on any material, any project, and every single time. I can be using cowhide, horsehide, Chromexel, etc .... It doesn't matter. I noticed the problem yesterday when I started sewing continuous stitches, whereas before I have always sewn 8" runs on holsters or small wallets. It does this every single time regardless of the material I am using. Every 30" to 31" it skips a stitch. Quote
Members DSloop Posted April 3, 2020 Members Report Posted April 3, 2020 Could the needle be getting hot and making the thread stick to it instead of being caught by the bobbin hook? Quote
Members Constabulary Posted April 3, 2020 Members Report Posted April 3, 2020 I don´t have a cobra but sometimes needle bars start rising a little bit. If it was me I´d check the NB height and maybe would try to lower the NB a little bit - maybe 0.5 -1mm. Just to start with... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted April 3, 2020 Moderator Report Posted April 3, 2020 Have you tried a new needle? Is the needle inserted all the way up in its mount? It it aligned with the rib on the left and scarf on the right? Do you have sufficient foot pressure to completely hold down the leather as the needle ascends? Lifting leather causes skipped stitches. Timing problem The hook timing may have moved from thread drag, or the needle bar may have raised up due to impacts and loosened screws. Power off before proceeding Remove the top thread beyond the wax pot or top post. Unscrew and remove the faceplate and set it aside. Remove the bobbin and shuttle cover plate. Set the stitch lever to the zero forward/backward motion position (rotate the hand wheel until it becomes zero feed). Use the hand wheel to move the needle all the way down to BDC. Continue wheeling slowly until the needle raises between 1/8 and 3/16 of an inch. Shine a light inside and see if the tip of the hook intersects the center of the needle above the top of the eye, inside the scarf area. If the hook and needle aren't intersecting above the eye at this point, determine if the needle is too high for the hook when the hook meets the needle position. If the hook is under the eye of the needle, loosen the 2 screws securing the needle bar, lower the needle bar until the eye is about 3/16" below the tip of the hook and lock down the screws. If the hook is arriving too late, it needs to be rotated clockwise to intersect the needle above the eye. If it is too soon, it needs to be rotated counterclockwise (looking at it) That is a matter for another reply and is fraught with room for serious error. It could affect the warranty. Did you get a manual with the machine? Have you called or contacted Cobra about this problem? This would be a good time to do so. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Bert51 Posted April 3, 2020 Members Report Posted April 3, 2020 If all the above checks out okay, check that your thread is coming off the spool smoothly and it's not getting caught any where. That has caught me before, all my thread stands are extra tall. Bert. Quote
Members RoosterShooter Posted April 3, 2020 Author Members Report Posted April 3, 2020 1 hour ago, Wizcrafts said: Have you tried a new needle? Is the needle inserted all the way up in its mount? It it aligned with the rib on the left and scarf on the right? Do you have sufficient foot pressure to completely hold down the leather as the needle ascends? Lifting leather causes skipped stitches. Timing problem The hook timing may have moved from thread drag, or the needle bar may have raised up due to impacts and loosened screws. Power off before proceeding Remove the top thread beyond the wax pot or top post. Unscrew and remove the faceplate and set it aside. Remove the bobbin and shuttle cover plate. Set the stitch lever to the zero forward/backward motion position (rotate the hand wheel until it becomes zero feed). Use the hand wheel to move the needle all the way down to BDC. Continue wheeling slowly until the needle raises between 1/8 and 3/16 of an inch. Shine a light inside and see if the tip of the hook intersects the center of the needle above the top of the eye, inside the scarf area. If the hook and needle aren't intersecting above the eye at this point, determine if the needle is too high for the hook when the hook meets the needle position. If the hook is under the eye of the needle, loosen the 2 screws securing the needle bar, lower the needle bar until the eye is about 3/16" below the tip of the hook and lock down the screws. If the hook is arriving too late, it needs to be rotated clockwise to intersect the needle above the eye. If it is too soon, it needs to be rotated counterclockwise (looking at it) That is a matter for another reply and is fraught with room for serious error. It could affect the warranty. Did you get a manual with the machine? Have you called or contacted Cobra about this problem? This would be a good time to do so. I'll try that this evening, and get back in the AM. Thanks for giving me multiple things to check out. I'll update once I go through this list. Thanks again. Quote
RockyAussie Posted April 4, 2020 Report Posted April 4, 2020 That also would be my best guess. Getting snagged at the bottom on a large spool would be about that sort of measurement I would think. Note that the knot shows its coming up higher as it comes to the missed stitches which also indicates a varying tension somewhere. Crooked sitting cone? Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members RoosterShooter Posted April 5, 2020 Author Members Report Posted April 5, 2020 (edited) On 4/3/2020 at 4:59 PM, Wizcrafts said: Have you tried a new needle? Is the needle inserted all the way up in its mount? It it aligned with the rib on the left and scarf on the right? Do you have sufficient foot pressure to completely hold down the leather as the needle ascends? Lifting leather causes skipped stitches. Timing problem The hook timing may have moved from thread drag, or the needle bar may have raised up due to impacts and loosened screws. Power off before proceeding Remove the top thread beyond the wax pot or top post. Unscrew and remove the faceplate and set it aside. Remove the bobbin and shuttle cover plate. Set the stitch lever to the zero forward/backward motion position (rotate the hand wheel until it becomes zero feed). Use the hand wheel to move the needle all the way down to BDC. Continue wheeling slowly until the needle raises between 1/8 and 3/16 of an inch. Shine a light inside and see if the tip of the hook intersects the center of the needle above the top of the eye, inside the scarf area. If the hook and needle aren't intersecting above the eye at this point, determine if the needle is too high for the hook when the hook meets the needle position. If the hook is under the eye of the needle, loosen the 2 screws securing the needle bar, lower the needle bar until the eye is about 3/16" below the tip of the hook and lock down the screws. If the hook is arriving too late, it needs to be rotated clockwise to intersect the needle above the eye. If it is too soon, it needs to be rotated counterclockwise (looking at it) That is a matter for another reply and is fraught with room for serious error. It could affect the warranty. Did you get a manual with the machine? Have you called or contacted Cobra about this problem? This would be a good time to do so. OK. I followed Al Bane's video online about checking the timing, and the machine is timed correctly. Now, for some unknown reason the machine is 'knocking' inside the Lower arm of the machine when I sew! This is getting frustrating. I don't recall having these issues with my Cowboy 3200 "Out of the Box". I'm getting to my wits end here. Edited April 5, 2020 by RoosterShooter Quote
RockyAussie Posted April 6, 2020 Report Posted April 6, 2020 Check that the screw that gets undone first when adjusting the bobbin tension has not worked its way out and hitting the race occasionally. Check there is no threads stuck down in the race. If they are not the problem..... to quote a very wise Wizcrafts... 2 hours ago, RoosterShooter said: Did you get a manual with the machine? Have you called or contacted Cobra about this problem? This would be a good time to do so. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Bert51 Posted April 6, 2020 Members Report Posted April 6, 2020 (edited) If I was to look for a noise in a machine, I would take off the drive belt and slowly turn it by hand until I find the noise, then I would start looking for where it is coming from. It could be like Brian said, a screw worked loose or a piece of lost thread that's found a new home or even the hook hitting the needle. But take your time and work your way through Wizcrafts list. Bert. Edited April 6, 2020 by Bert51 spelling Quote
