Members palvim Posted April 9, 2020 Members Report Posted April 9, 2020 Hello All, I've been reading through a lot of the posts on this forum and it is so informative. Thank you all! It is very helpful to a super newbie like me. I'm writing as I just started to get an issue with the front and back stitch being misaligned. As in they don't go in the same hole. It worked fine u til yesterday when I tried to stitch on the fold of a folded belt. I think it might have screwed up something at that point. Now everytime I back stitch, the backstitch goes 2 stitches back i.e. 1 back stitch = 2 forward stitches. Please see the image attached. Any idea what went out of alignment or how to fix this? Any help is super appreciated! Thank you. Quote
Members palvim Posted April 9, 2020 Author Members Report Posted April 9, 2020 I also read up on one topic that inside foot and the feed dog should meet each other just when the needle is going down on the feed dog. I see that is not the case on my machine. Is this something that is the problem? The image attached is exactly at the point where the feed dog meets the inner foot. Quote
Moderator Wizcrafts Posted April 9, 2020 Moderator Report Posted April 9, 2020 Did you make an adjustment to the height of the inside foot before this occurred? If not, loosen the big bolt on the crank coming out the back left side and lower the needle to the level of the feed dog, then drop the inside foot to meet it and lock down the bolt. Maybe your bolt loosened itself. The feed dog should have risen to the top of the throat plate slot when the needle meets it, but should not start moving back at that point. Set this with the stitch lever in the zero motion position to be most accurate. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members palvim Posted April 9, 2020 Author Members Report Posted April 9, 2020 Thank you wizcraft for replying. Do you mean the opening on the back of the machine? I am a little lost. Do you mean the bolt on this thick metal bar or is it inside the opening somewhere? Quote
Moderator Wizcrafts Posted April 9, 2020 Moderator Report Posted April 9, 2020 Wrong end! The crank I am referring to comes out the back near the very left side of the head. It connects to the presser foot cranks inside the left end. When you remove the faceplate you can see these parts. I'm not able to go to my shop so no photos from me at this time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted April 10, 2020 Members Report Posted April 10, 2020 wild guess - is it possible that the machine is just skipping a stitch in reverse? Its very unlikely that the F & R stitch length differ by exactly 50% (as it seems). Is it possible that it is just a needle / hook timing issue? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members palvim Posted April 10, 2020 Author Members Report Posted April 10, 2020 48 minutes ago, Constabulary said: wild guess - is it possible that the machine is just skipping a stitch in reverse? Its very unlikely that the F & R stitch length differ by exactly 50% (as it seems). Is it possible that it is just a needle / hook timing issue? Would it randomly miss or consistently miss? On my machine it is consistently doing reverse at twice the length of the forward stitch Quote
CowboyBob Posted April 10, 2020 Report Posted April 10, 2020 4 hours ago, Constabulary said: wild guess - is it possible that the machine is just skipping a stitch in reverse? Its very unlikely that the F & R stitch length differ by exactly 50% (as it seems). Is it possible that it is just a needle / hook timing issue? Yes,I'll agree that's what it looks like to me too.You might try to tighten your foot pressure a turn or two. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Michiel Posted April 10, 2020 Members Report Posted April 10, 2020 If you turn the machine by hand (slow) you can see if the stitch in reverse is longer or constabulary is right (my guess would be you are missing stitches in reverse...) regards michiel Quote
Members palvim Posted April 10, 2020 Author Members Report Posted April 10, 2020 Here is the video of how I'm trying to do it. I tightened the presser foot tension to at least 3 turns. And here is with the bobbin cover off. And here is the movement of the feed dog, presser foot and inner foot in relation to each other and the bobbin. Appreciate your help very much. Thank you. Mano. Quote
