Members Spyros Posted May 23, 2020 Author Members Report Posted May 23, 2020 29 minutes ago, Alden said: if you become a member at Leffler it is cheaper.They do have scrap bins with various leathers including kangaroo which is perfect for watch straps and wallets etc. Strapping for belts even Sedgwick bridle . Yeah if your doing a leather Tote bag then you'll be up for a hide and that starts at around 150AUD! watch straps are great for practice and use very little leather while really challenging you Yeah I did a NATO from the same hide I did the tote, I was really proud that i custom made it for my wrist and it only had one hole, I was the only person I knew with a single hole watchstrap And then I started wearing it and it stretched to buggery, now it looks like swiss cheese LOL Quote
Members Scoutmom103 Posted May 23, 2020 Members Report Posted May 23, 2020 (edited) Nice job on the stitching pony, maul, awls, and the chest. They are really nice. I would be interested in info on the stitching pony. My husband has begun to do more woodworking and has shown interest in making things to help me in my leatherworking. My current pony is small and isn't really designed to clamp onto the edge of a bench. The tote looks nice. Edited May 23, 2020 by Scoutmom103 Not enough coffee yet this morning. Quote
toxo Posted May 23, 2020 Report Posted May 23, 2020 7 hours ago, Spyros said: Yeah I did a NATO from the same hide I did the tote, I was really proud that i custom made it for my wrist and it only had one hole, I was the only person I knew with a single hole watchstrap And then I started wearing it and it stretched to buggery, now it looks like swiss cheese LOL I would just say that it's not best practice to sew all the way across a watch strap. Someone on here mentioned that they'd found a rather expensive watch that had given way at the stitch line. Quote
Members Spyros Posted May 23, 2020 Author Members Report Posted May 23, 2020 (edited) 6 hours ago, Scoutmom103 said: Nice job on the stitching pony, maul, awls, and the chest. They are really nice. I would be interested in info on the stitching pony. My husband has begun to do more woodworking and has shown interest in making things to help me in my leatherworking. My current pony is small and isn't really designed to clamp onto the edge of a bench. The tote looks nice. Sure, although I must warn you it's probably not the easiest build. It requires some accurate freehand radius cutting on a 12" or bigger bandsaw, a router table and some specialised hardware like a T-track and the blue cam clamp that runs on it, but you can find those things in most woodworking shops like Rockler for example. Also a couple of threaded rods, a spring and some nuts and washers, just typical hardware store stuff. I chose to make my own star knobs out of wood but you can find ready made plastic ones on ebay for a couple of bucks. Overall depending on quality there's probably about $50 of materials in this thing but it can be made cheaper if you skip the T-track and the fancy cam clamp (that thing was USD$16, I only used it because I had one leftover from another project). You can also laminate plywood instead of solid timber for cheaper. The T-track is not really necessary, I put it there so I can lift the upper part of the pony a little bit higher so that the whole thing can fold into itself for storage, which can be achieved with a slightly different design, and to offer a bit more flexibility on the table to position the clamp exactly where I want it. I guess I did a few things the hard way on this pony, I'm sure I can come up with a simpler way. For example I made the clamp with a loose bottom jaw that clamps but doesnt turn (which was a giant pain to make), because i didn't want it to scratch the bottom of my table every time I clamp it. But now I see the other popular ponys on etsy etc that don't have that so maybe nobody cares about the bottom of their tables LOL Now I'm looking at youtube to see if someone has made a similar type of pony because it's probably easier to show you than type instructions, but I can't find anything. Check with your husband if it doesn't sound like too much trouble and he still wants to have a go, and if so I'll put together a pattern or instructions for you. Edited May 23, 2020 by Spyros Quote
Members Spyros Posted May 23, 2020 Author Members Report Posted May 23, 2020 1 hour ago, toxo said: I would just say that it's not best practice to sew all the way across a watch strap. Someone on here mentioned that they'd found a rather expensive watch that had given way at the stitch line. Yeah I can see how that might happen... didn't think about it to be honest. Anyway I'll probably need to make it again soon as this leather is way too stretchy, just not meant for this type of thing. Quote
Members Scoutmom103 Posted May 23, 2020 Members Report Posted May 23, 2020 2 hours ago, Spyros said: Sure, although I must warn you it's probably not the easiest build. It requires some accurate freehand radius cutting on a 12" or bigger bandsaw, a router table and some specialised hardware like a T-track and the blue cam clamp that runs on it, but you can find those things in most woodworking shops like Rockler for example. Also a couple of threaded rods, a spring and some nuts and washers, just typical hardware store stuff. I chose to make my own star knobs out of wood but you can find ready made plastic ones on ebay for a couple of bucks. Overall depending on quality there's probably about $50 of materials in this thing but it can be made cheaper if you skip the T-track and the fancy cam clamp (that thing was USD$16, I only used it because I had one leftover from another project). You can also laminate plywood instead of solid timber for cheaper. The T-track is not really necessary, I put it there so I can lift the upper part of the pony a little bit higher so that the whole thing can fold into itself for storage, which can be achieved with a slightly different design, and to offer a bit more flexibility on the table to position the clamp exactly where I want it. I guess I did a few things the hard way on this pony, I'm sure I can come up with a simpler way. For example I made the clamp with a loose bottom jaw that clamps but doesnt turn (which was a giant pain to make), because i didn't want it to scratch the bottom of my table every time I clamp it. But now I see the other popular ponys on etsy etc that don't have that so maybe nobody cares about the bottom of their tables LOL Now I'm looking at youtube to see if someone has made a similar type of pony because it's probably easier to show you than type instructions, but I can't find anything. Check with your husband if it doesn't sound like too much trouble and he still wants to have a go, and if so I'll put together a pattern or instructions for you. Thanks Spyros. The band saw my husband owns isn't even 12" nor does he have a T-track and the blue cam clamp. Quote
Members Spyros Posted May 24, 2020 Author Members Report Posted May 24, 2020 (edited) 7 hours ago, Scoutmom103 said: Thanks Spyros. The band saw my husband owns isn't even 12" nor does he have a T-track and the blue cam clamp. That's alright, you can make it out of 3/4 inch plywood which is easy to cut in a small bandsaw, and we'll skip the track. Ok so first step is to cut some 2inch by 10 inch pieces of plywood, make about 10 of them because there will be mistakes for sure. Then print this and glue it on 8 pieces (sorry about the hand drawing but it would take me forever to make those curves in sketchup) and cut them out on the bansaw. I guess you could also cut with a jigsaw or coping saw, but it's harder and it will take longer. Now about this shape, these are obviously the jaws of the clamp. If you want to make them a different curve, or maybe a couple of inches longer so you can clamp bigger leather pieces in there, you can, it's up to you. But dont make them much longer than that because then I'm not sure if the clamping mechanism will work properly. 1-2 inches should be fine, if I was making mine again I'd probably do that actually. In terms of cutting them. Those pieces need to be as identical as possible, but again it's really up to you how pretty you want your pony to look. If they are not completely identical it will still work fine. The method of making identical ones depends on if you have a router and a flush trim bit. If you do then you make one piece as perfect as you can, sand all the curves to perfection etc, and you use it as a template. This guy explains it well: If you don't have a router just do the best you can cutting them as identical as you can, and in the end of the project when everything is glued and ready you can file and sand down the pieces that stick out. But it's best to avoid that as much as possible because sanding curves is a bit of a PITA. Let me know how this sounds so far, if it sounds doable I'll continue with the next steps. Edited May 24, 2020 by Spyros Quote
Members Scoutmom103 Posted May 24, 2020 Members Report Posted May 24, 2020 Thanks Spyros. It sounds like it's doable. Quote
Members Spyros Posted May 25, 2020 Author Members Report Posted May 25, 2020 Cool, cool Alright so now you should have 8 of those curvy pieces. If you stack them together in two piles facing eachother you have the basic shape of the two jaws of your clamp. Take the the two middle pieces of each stack and cut them shorter from the bottom along the lines I've marked below. The two middle pieces from the right stack will be cut a little shorter than the other two. Quote
