Every time I use my airbrush I clean it after using a cheap ultrasonic cleaner that I have.  Some airbrushes are a pain to disassemble, others not so much.  Thankfully, my Paasche and Iwata are both reasonably easy.  Never a problem!
- Bill
20 hours ago, fredk said:
a. check the needle tip. rub it down with some fine grade wet & dry paper. it may not be needle sharp, it may have a slight kink in the very tip
b. clean out the nozzle cups, there maybe a speck in there.
It doesn't take much to make a spray brush go wonky.
Thanks, I will give the sand paper on the needle a try.  The cup seems pretty clean.
also clean the nozzle cups at the nose. You should have two; an outer and an inner one. One of my airbrushes was splattering and I got out of the inner one a speck the size of this  . which was the problem. Get a a set of the fine airbrush cleaning brushes. They are worth the couple of $$ they cost
- Bill
Never thought about that!  My next shop buy. Thanks!
Will do, thanks!
  • 1 year later...
Anyone would reccomend a good one for a beginner?
Edited by Mocivnik
What price can you afford? If I had a guide on that I could recommend something
