CFM Frodo Posted June 15, 2020 CFM Report Posted June 15, 2020 (edited) looking for recommendations for a closure for a cell phone holster that will be used frequently Magnet is not strong enough post would scrape every thing snaps wear out the leather Suggestions? Edited June 15, 2020 by Frodo Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member fredk Posted June 15, 2020 Contributing Member Report Posted June 15, 2020 I use a 'Sam Brown' stud on my phone holster. Inside the holster the screw part is covered with a piece of pigs-skin lining Quote Al speling misteaks aer all mi own werk..
Members jcuk Posted June 15, 2020 Members Report Posted June 15, 2020 Velcro or put a loop on the case so you slide the strap end into it. Hope this helps JCUK Quote
Contributing Member fredk Posted June 15, 2020 Contributing Member Report Posted June 15, 2020 I find that with frequent use velcro becomes useless. tbh when I make a new phone holster I'll be doing the the strap & loop closure. The SB stud can be a nuisance Quote Al speling misteaks aer all mi own werk..
Contributing Member LatigoAmigo Posted June 15, 2020 Contributing Member Report Posted June 15, 2020 1 hour ago, Frodo said: snaps wear out the leather I understand your issue, I've faced the same problem, but I'm curious... what do you mean that "snaps wear out the leather"? Quote
Members jcuk Posted June 15, 2020 Members Report Posted June 15, 2020 (edited) 43 minutes ago, fredk said: I find that with frequent use velcro becomes useless. tbh when I make a new phone holster I'll be doing the the strap & loop closure. The SB stud can be a nuisance There are many makes and types of velcro/Hook and Loop on the market some are a lot better than others, i have made many weight cloths for jockeys in racing using this method it seems the safest way to me to keep the lead in the weight cloth have seen snaps fail at times. JCUK Edited June 15, 2020 by jcuk Quote
CFM Frodo Posted June 15, 2020 Author CFM Report Posted June 15, 2020 3 hours ago, LatigoAmigo said: I understand your issue, I've faced the same problem, but I'm curious... what do you mean that "snaps wear out the leather"? Frequent pulling the leather snap causes the hole for the snap to elongate . after a period the snap comes through the leather I am referring to multiple times per day . Not 1 time a day type use Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member LatigoAmigo Posted June 15, 2020 Contributing Member Report Posted June 15, 2020 (edited) 1 hour ago, Frodo said: Frequent pulling the leather snap causes the hole for the snap to elongate . after a period the snap comes through the leather I've imagined that the leather could stretch and cause the cap to come loose, so I've always punched a hole slightly smaller than the shaft on the snap's cap, then use a snap setter so that the cap is set with very even pressure. I'm not sure it did any good, but I sure felt better about it. Edited June 15, 2020 by LatigoAmigo Quote
Contributing Member fredk Posted June 15, 2020 Contributing Member Report Posted June 15, 2020 Some snaps are incredibly difficult to open. If I have any of these I run a file around the ridge above the groove which the spring grips. I take just a smidgen off it. This loosens the grip just a tad. The snap still hold tight but it just doesn't need that screwdriver to open it. Another thing I've had to do is put a piece of thin brass between two layers of leather. A hole in the brass for the snap's shaft to go thru and the brass extending to where a person grips to pull the snap open. This was on a repair - improvement where the leather had stretched and pulled out over the head of the snap Quote Al speling misteaks aer all mi own werk..
Members Dwight Posted June 16, 2020 Members Report Posted June 16, 2020 I long, long ago gave up screwing around with fasteners for cell phones. Too easy to make this one, . . . works like a champ, . . . 7/8 oz leather, . . . metal belt snap on the back . . . held together with rivets. This one holds a samsung note 8 with it's kinda rubber like case around it, . . . I wear it in/on the computer chair, . . . dinner table, . . . tractor, . . . zero turn, . . . quad, . . . Jeep . . . van . . . up & down ladders . . . never dropped a phone out of it yet . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
