  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
Try on thing.  Loosen the thumb screw in front  a that lock the machine foot from rotating.  Sometimes they are screw up a little to far for the foot to rotate.
glenn
On 6/27/2020 at 12:54 AM, 24602 said:
thanks Glenn,  you cannot see it because it blends into the cabinet behind but it does have the drawer. I found it in a box of stuff  the seller gave to me.
Thanks for the paint idea.
The foot rotation does not want to loosen up.  I’ve been giving it the wd-40 and turning it around but it isn’t changing. Actually it gets worse at times. It doesn’t help I’m not sure what it should be like but I’m sure it shouldn’t be as tight as it is and shouldn’t get tighter at times. Any advice.
Since it isn't loosening up yet,you could try to take the head off the stand & lay it on the backside then take the thumbscrew off the head(the one that locks it so it won't rotate) & spray WD in there,you'll be able to get more in it & then spin it again.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Not wanting to add doom and gloom to this topic, but I thought I should mention that if the little paddle shaped thread control spring inside the head is bent out of alignment it will drag as you revolve the head. If you listen carefully while revolving the butterfly handles, you might hear the sound of metal scraping against metal in certain points of rotation. The spring lives just above the needle mounting block.
Replacing this spring is a work of art in itself. I don't have time to go into it now.
Posted IMHO, by Wiz
15 hours ago, Old Coach Saddlery said:
I have done a few stuck  Singer Patchers without having to disassemble. Oil her up good and keep rotating. So much so that it drips.
You know the scenario - you’ve got sick child. You wait and wait not wanting to go to the dr. Once you make the appointment the child turns the corner and is on the mend. I threatened to take apart and it finally let loose. Still one stickyish spot in the rotation but it will get there.
Neat machine. Going to thread it today and see how it stitches. It came with a bunch of needles. 120,130,140,160, and 180. Box of thread also but mostly unlabeled so I mine not sure if there’s anything in the box to fit the big 180 needle. According to Bob’s needle/thread chart that would be between a 207 and 277. Will this machine take thread that big?
some do some don't. I have seen an OEM manual where its mentioned that the machine is sewn off in the factory with #11/3 metric thread which is equal to 207. Needle plate hole has to be wide enough and the thread hole in the hook as well to run 207.  Some other fine tuning may be required. 138 is possible all day but 207... you never know... I would not expect it.
So what would you guess someone was doing with 160 and 180 needles?
maybe it is set up for 207 - I don´t know. Sometimes needles from different machines mix up and find their way into the wrong accessory box. You would not believe what I found in accessory boxes. Best find was a Luger 08 wrench / take down tool (not kidding).
Edited by Constabulary
Treasure finds are so fun!
So the sticky point is gone. The butterfly turns smooth all the way around. Cleaned up the wd-40, oiled, threaded, and stitched a decent stitch. Will work on tensions and larger thread possibilities. It does have the second set of tensioning discs that the manual said was subclass for heavier thread. The treadle belt is a little loose so will need to trim and tighten that up.
A little more show and tell:
AB296907-98BA-4D47-9C03-EE282944E238.jpeg.08a07a2d2df693a2fcf2d97e95c24f34.jpegOriginal plastic cover. Prety good shape other than the stitching has let go. Will hand sew it back together. 9674FC47-FFA7-4063-85AE-D6CB94FC2B01.jpeg.e57e3a47fc430101b84b4bef7a1a103d.jpeg
Adler oil bottle. AA553975-42B1-47B0-BEF4-ADBF80955E6B.jpeg.e5c8214034f3783acbc5f2e9747d3f8f.jpegE14FD8BE-D1AE-4CEC-B1A7-35E7979355B3.jpeg.5f5f4586072789c374934efbdcdaa9a5.jpeg
I’m assuming this was the test stitching from the factory. I think it says: Nachkodrolle 3. Can’t make out the letters between the o and r very well. Also seems like it was sewn off with fairly heavy thread. Didn’t realize what this was til just a few minutes ago.
Edited by 24602
