Members AMule123 Posted July 23, 2020 Members Report Posted July 23, 2020 Hi all, I tried to post an absolute essay of a question yesterday and it didn’t work, probably cos it was too long haha Ill summarise; Im looking at getting a 441 clone, to replace the handstitching on my 6oz leather bags. being in Australia I was looking at a cowboy 4500 from Queensland. But as I’m in Sydney I was looking for a local supplier and found a used seiko ch-8b with a brand new servo and speed reducer, from a sewing machine supplier 20minutes from me, for slightly less than the cowboy would work out with shipping. i just met the guy and his seiko and it runs beautifully with the leather and threads I’d like to use. heres the question, with a limited (3month) warranty on the seiko, am I better off with a longer warranty on a brand new machine? he couldn’t tell me how old the seiko was, but it looked great. thanks in advance! you guys have already been such help! Sam Quote
Members Matt S Posted July 23, 2020 Members Report Posted July 23, 2020 FWIW Seikos are very well built machines. It takes a lot of use to wear one of them out. One of mine had 20 years of factory use and 10 years of disuse before it came to me, and I don't think it's missed a beat ever since. My preference, all other things being equal, would be for an older machine from a premium manufacturer over a newer Chinese-built machine. I'm sure that there are many well made Chinese machines, especially those that have been set up and warranted by respectable dealers, but I've got my fingers burned a few times and I have a taste for quality tools -- I have been spoiled by using Singer, Adler and Seiko! Consider also that that Seiko has probably depreciated in value as far as it's going to any time soon, whereas if you sell it the day after you buy it that Cowboy may have dropped 20%. Are you likely to want much in the way of accessories for your machine? Flat bed tables, specialist feet, edge guides etc. I ask as there is far fewer aftermarket stuff available for the CH8 than the 441 type. Quote
Contributing Member Ferg Posted July 23, 2020 Contributing Member Report Posted July 23, 2020 (edited) This is a photo of a Seiko I sold recently. Great machine except I think my Servo was a dab too small for it. Used it for purses mostly and some belts also. #138 thread is what it likes most. Don't believe I tried any 207 with it. Will stitch 7 or 8 oz. of leather all day long. Much over that really makes it chug. Remember, I said I think my servo was too small. Well built, the Cowboy is pretty much a carbon copy. I sold mine for about $1400 if I remember correctly. The above machine was a CH-8B-Ld Ferg Edited July 23, 2020 by Ferg Quote
Moderator Wizcrafts Posted July 23, 2020 Moderator Report Posted July 23, 2020 1 hour ago, Ferg said: he above machine was a CH-8B-Ld Ferg, I believe you had a CW, not a CH. The CH is a 441 clone of the Juki TSC-441. Yours is a clone of a Singer 153. http://www.seiko-sewing.co.jp/en/products/cwseries/ Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member Ferg Posted July 23, 2020 Contributing Member Report Posted July 23, 2020 You are correct Wiz, I found another photo showing the "CW". Ferg Quote
Members AMule123 Posted July 23, 2020 Author Members Report Posted July 23, 2020 Thanks all! Appreciate your responses. yeah I’ve been leaning toward the seiko, but the available attachments are a concern to me. I imagine I can make a flatbed attachment, and the dealer has offered me a guide, but it’s the swing out variety, as opposed to the drop down, which does limit its usefulness to me. He has also modified the feet, removing the right hand one and shortening and narrowing the left one, but also has a spare set of original feet. and finally it has a slotted throat plate instead of the original bottom feeder, apparently for saddlers to save the underside from marking. What limitation would this impose? What kind of specialist feet are available for the 441 that would not be for the seiko? thanks again! Sam Quote
Members dikman Posted July 23, 2020 Members Report Posted July 23, 2020 (edited) Sam, you mentioned #138 thread, if that's what you want to use then the Seiko will probably be the better machine. The 441 will be overkill for your bags. Realistically, unless you intend to make holsters, heavy gunbelts and do harness work a 441 will be too much machine and you'll probably end up fighting it when sewing lighter work. I agree with Matt, Seiko are solid well-built machines, when I decided to reduce the number of machines I had I sold the Singers and kept the Seiko. As for the 3 month warranty if you start using the machine you should soon discover if there are any issues within that warranty period. edit:you posted just as I did. I fitted a generic drop-down guide to mine, it was simply a matter of making a suitable bracket to attach it (nothing fancy). Another edit: I just realised I had the wrong model in mind (I should have looked it up before commenting - dumb!). The Seiko is pretty much their version of the 441. However, if you've tried it and it sews what you want then that's the one to get. I have a 4500, bought from the Qld folks, and I'm happy with the quality of the machine but the Seiko will definitely be a better quality machine. Plus you have the advantage of someone nearby if you do have questions/issues. And it's all set up and working. Edited July 23, 2020 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members AMule123 Posted July 24, 2020 Author Members Report Posted July 24, 2020 Thanks Dikman! yeah I’d considered that a 441 might be overkill, as I’m not planning on making saddles any time soon, but I’d rather have more machine than less, and the bags that I’ll be making will at the very top have about 12-13mm thickness, so it will give me room to move up, without getting a different machine. I do make wallet and other small leathergoods, but I plan on continuing to hand stitch those, it’s just gonna be the bigger bags that I can’t see myself handstitching for much longer! also I’d like to use a size 207 thread for detail stitching, to somewhat replicate hand stitching. good to hear re the drop down guide! Do you have a photo of yours? thanks Sam Quote
Members dikman Posted July 24, 2020 Members Report Posted July 24, 2020 I'll take one later and post it here. It's not difficult, just a matter of cutting a suitable piece to line up with the holes in the machine and those on the guide. I had to do the same with the 4500. Does the 4500 come complete - table , motor and speed reducer? I assume you're dealing with the same people I dealt with (Jess)? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members AMule123 Posted July 24, 2020 Author Members Report Posted July 24, 2020 22 minutes ago, dikman said: I'll take one later and post it here. It's not difficult, just a matter of cutting a suitable piece to line up with the holes in the machine and those on the guide. I had to do the same with the 4500. Does the 4500 come complete - table , motor and speed reducer? I assume you're dealing with the same people I dealt with (Jess)? Thank you! That would be greatly appreciated! Yeah I think it’s Jess, and yes comes complete. Quote
