Members LomaeArts Posted August 14, 2020 Members Report Posted August 14, 2020 (edited) I recently acquired a Pedersen Model 308 Sole Stitcher. I am yet to try stitching as it is cocered in years of dust and grime. I have read most of the threads here. As well as a manual I found. My meachanism looks great and works sell. My reading shows: the bobin thread has to be waxed the top thread is not waxed you stitch Welt up However what is not clear ( lack of detailed picture) is: How to adjust the bobbin tension, How adjust the stitch length Does the thread need to be waxed Do I need to grove the sole Any assistance on these will be much appreciated. Edited August 14, 2020 by LomaeArts further research done Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members Constabulary Posted August 14, 2020 Members Report Posted August 14, 2020 (edited) I once had a Junker & Ruh SD28 but it did not suit my needs. I was able to sew unwaxed 207 Poly + linen thread w/o problems (top + bottom). Screw #32 is for adjusting the top thread tension Screw 25 is for the stitch length BTW - I can send you a German language manual with better pictures - just send me a PM Edited August 14, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
RockyAussie Posted August 14, 2020 Report Posted August 14, 2020 You may already have this manual but in case here is this one - https://www.bootmaker.com/Junker_Ruh_Manual.pdf Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members LomaeArts Posted August 14, 2020 Author Members Report Posted August 14, 2020 Constabulary - PM sent, those images are so good. RockyAussie - yeah I have that manual. Ok UPDATE. I degreased and oiled the stitcher. I threaded it with 150D waxed thread as that seems to the size that was on the machine. Initial observations: it is super easy to use The waxed thread works well the needles that came with it are #6 and lots of #7. these are big. the stitch length is about 4 to 6 mm the Tension needs attention I like using more than my Landis model 12 due its simplicity. The photos below show the unit on my dining room table Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members LomaeArts Posted August 25, 2020 Author Members Report Posted August 25, 2020 (edited) I started to try stiching with the Pedersen Model 308. After repacking and adjusting the tension spring, i got some great stiches. Then is stopped stiching - IE the top tread doesn't look the bobin. I note the shuttle and bobin as very slopy, and wonder if it is the cause of the issue. changing the needle didn't help. Edited August 25, 2020 by LomaeArts spelling and needle Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members Handstitched Posted August 26, 2020 Members Report Posted August 26, 2020 I know nothing about them, never seen one before, but that is just beeeautiful , lovely and old HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Constabulary Posted August 26, 2020 Members Report Posted August 26, 2020 (edited) Shuttle has to be sloppy - its is a so called elastic shuttle which is oscillating and the thread is pulled UNDER the shuttle while forming the stitch - it is just like a patcher shuttle just a lot larger. What kind of leather are you using? This machine is designed for stitching stiff / rigid shoe sole leather. Edited August 26, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members jimi Posted August 26, 2020 Members Report Posted August 26, 2020 I,am Not Sure about these Junkers/Pederson type models, but normally the bobbin post has a tension spring also?? at least on other sole stitchers. Quote
Members LomaeArts Posted August 29, 2020 Author Members Report Posted August 29, 2020 Thanks for the replies. I have included a sample I was doing before it quit on me. Constabulary: that is a good explanation. I am stiching 5.5mm bridle leather that is a bit softer that sole leather. I am starting to think i have a tension issue as I fine the tread slides under the trnsion discs and jams. jimi: The bobbin tension hasn't changed, but is pretty tight. Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members LomaeArts Posted August 29, 2020 Author Members Report Posted August 29, 2020 On 8/26/2020 at 9:06 PM, Handstitched said: I know nothing about them, never seen one before, but that is just beeeautiful , lovely and old HS Yeah, it hwas a display item in the shop I bought. I like a lot and if I can make it reliable will using on hand made leather sandles. Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
