Members Hawker Posted September 15, 2020 Members Report Posted September 15, 2020 Hi all, I have a singer 44-81 glove machine, the one that sews and trims the leather close to the sewn edge. The Singer manual states it uses 16 x 97 Needles and I can not locate any. I’ve tried my local sources only to be told they have never heard of this size. Does anyone have a lead on needles or any assistance they could offer up. It would be much appreciated as I have this machine to make falconry gloves and I’m really looking forward to seeing what it can achieve. Thanks in advance! Quote
Members Constabulary Posted September 15, 2020 Members Report Posted September 15, 2020 Most likely the Singer 16 needles range will work. Other ID´s are DBx1, 287 or 1738. Its a quite common needle for vintage machines. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted September 15, 2020 Moderator Report Posted September 15, 2020 1 minute ago, Constabulary said: Most likely the Singer 16 needles range will work. Other ID´s are DBx1, 287 or 1738. Its a quite common needle for vintage machines. I was just about to tell him to try this needle system. It may or may not be necessary to slightly raise or lower the needle bar to get perfect timing. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members machinehead Posted September 15, 2020 Members Report Posted September 15, 2020 Long ago I found a needle reference chart on the net that listed many obsolete systems. This list went into much more detail of needle specs than just length ,diameter, etc. Unfortunately, I found it shortly before my computer died and I didn't have it in backup. Best I remember the 16x97 was much longer than any other 16 needle and again if memory serves it was much longer than other needles with the same or similar diameter. Someone once posted a page from this list here on the forum but I can't remember who or where. One of the dealers here on the forum may have this very list and be able to help with the specs. Quote
Members Constabulary Posted September 15, 2020 Members Report Posted September 15, 2020 I have an old needle chart but the 16x97 is not pictured but a few other Sys. 16 needles, most seem to be 39mm long one is 43mm long as it seems. So I would look for a common Sys. 16 needle and adjust the needle bar as Wiz said. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Hawker Posted September 16, 2020 Author Members Report Posted September 16, 2020 Hi all, I have a singer 44-81 glove machine, the one that sews and trims the leather close to the sewn edge. The Singer manual states it uses 16 x 97 Needles and I can not locate any. I’ve tried my local sources only to be told they have never heard of this size. Does anyone have a lead on needles or any assistance they could offer up. It would be much appreciated as I have this machine to make falconry gloves and I’m really looking forward to seeing what it can achieve. Thanks in advance! Quote
Members Handstitched Posted September 16, 2020 Members Report Posted September 16, 2020 @Hawker G'day, firstly , I looked up your machine, https://www.manualslib.com/manual/364550/Singer-44-79.html?page=4#manual And you're right about the needle size. I did have a look around , but all I could find, for the moment, is this: https://www.sewingmachinesaustralia.com.au/shop/buy-accessories/needles-by-machine-type/plain-sewers-1/leather/needles-16x230lr-leather-point-100-needles.html . The other side of the world I know, and no help to you . This is my parts supplier I'll keep looking . HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Handstitched Posted September 16, 2020 Members Report Posted September 16, 2020 I have never done business with this mob but , it does reference Singer. https://www.amazon.com/Pieces-Needles-Machine-Bottles-Brother/dp/B07VC8D1SM HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Matt S Posted September 16, 2020 Members Report Posted September 16, 2020 Hmm yeah that looks to be an oddball needle class. Did the machine come with an old needle that you might be able to measure? You may be able to figure out an equivalent. Other 44-class machine use a variety of 16- and 31-class needles. Perhaps you could adjust your needle bar height to suit one of these more common needle classes? Quote
Members Constabulary Posted September 16, 2020 Members Report Posted September 16, 2020 (edited) You asked the same question a couple hrs ago and got some responses already Edited September 16, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
