I made two coin pouches. I used the Tandy "2 pocket coin purse" as a template, but only did one pocket because I wanted to keep the thickness down. I used some oil tan scraps I bought at the store and cut them out using razor scissors. The first pouch I did is in black with black thread. I wasn't happy with it because the margin on one side is wider than the other side. So I made a brown one (after 3 failed attempts). I used diamond chisels to make the holes. The thread is not anything special, just what I bought at Tandy.
Despite reading many tips on how to make the holes in the corners, it is much easier said than done! Despite using my oversitcher wheel, I did have to fudge some holes along the bottom right of the brown pouch, and when I used my single-point chisel I was not aware that I was holding it the wrong way and thus have a vertical diamond hole. Oops.
Question: why does my saddle stitch look like zig-zags (slanted with a gap) on one side and normal (straight, no gaps between stitches) on the other side? On the black piece, the stitching looks normal on the back and zig-zag on the front. On the brown piece, the stitching looks normal on the front and zig-zag on the back.The only thing I can think of is that I did the "cross over" of the needles wrong. I did not put them in the hole simultaneously, because in the past I have broken needles that way. So I threaded one hole first (needle #1), and then played "catch up" with needle #2, while holding down needle #1's thread so that it didn't get in the way (both needles' threads being on the same side of the hole when I started to "catch up"). On the black pouch, I did this on the front of the piece; on the brown pouch, I did this on the back.
Do you think I should get more leather and try again? Or do you think these are okay enough to be gifts? I am my own worst critic!
Edited by Alaisiagae
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Welcome to the world of saddle stitching. For starters i would go to Nigel Armitage on youtube and vimeo. An excellent teacher! Once you learn the basics the main thing is to make sure no matter how you do it, it is done the same every single stitch. Each needle goes in the same place, same side first, thread crosses, etc. After that it is just practice.
May God Smile on you today.
Couple of things might be going on.  First, which diamond chisels do you have?  And how many teeth?  Do you have a 2-tooth chisel?  You'll want to use a 2-tooth chisel to do the radiused portions.  Corners only exist if you square off the stitching really, like a 90 degree angle.  In that case, you want a round hole, not a diamond-shaped hole in order for the stitching to look the same on both sides of the hole.  Nigel Armitage calls this a "hinge" and trust me, it looks far better than trying to use a flat awl or a diamond-shaped chisel.
So use your big chisel, 4 to 10 tooth or whatever up until it begins curving and then you switch to the 2-tooth until it flattens out again and repeat as necessary.
As far as the orientation of the stitches, you have to choose which side of the work you wish to be the "front", even if technically both sides could be considered a "front".  Then stay consistent with your needle priority.
There is usually a difference between the front and the back stitching lines.  It can be minimized using various techniques and adding a cast to the stitching process, basically a half-knot.  This is explained in Nigel's videos on stitching.
Another thing that greatly affects the angle of the stitching is the overall thickness of the leather.  Very thin leather makes it hard to get a good angle on the back.  I find the more layers I'm working with the better the backside is going to appear.
So if you haven't already, please take the time to go to youtube and look at Nigel's videos.  He talks at great length on stitching chisels, how they are properly used, how they differ from pricking irons, etc.  He covers the basic saddle stitch in detail and you'll find it very informative.
Good luck!
And by the way, your projects would be cherished if you were to give them away "as-is".  They were lovingly handmade.  What's better than that?
@Tugadude I have the Craftool diamond hole chisel set. It comes in three spacing widths, with 2, 4, and 6 teeth (and a single 1 tooth). I used the tightest width (3/32") for the brown pouch, and the middle width (1/8") for the black pouch. I did use the 2 tooth chisel when making the corners, but I may have lined it up poorly or at a suboptimal angle along my stitching line (I'm thinking of the left front radiused corner on the brown pouch. The right side looks good).
Okay, so it's normal to have the front and back stitching look different? That's a relief, at least I know what to expect now. I think the pieces I worked with are in the 4/5 oz range (I'd have to use my thickness gauge on it to be sure). Much thicker than the thin veg tan that came in the Tandy kit, and thus why I opted for a single pocket rather than a bulkier 2 pocket pouch. I could buy thinner oil tan (I really enjoyed working with it, so flexible and pretty!)...
I plan to give them to my uncle for the holidays, and fill them with those chocolate coins you see at Christmas time. ^_^
I admit, I was wanting for a better cutting implement when cutting out the leather. Keeping my scissors from skewing (yaw or pitch?) was hard, and I don't like using my utility knife (pull-cut). But those round/head knives look intimidating with a hard learning curve. Even the tools I used for these pouches had their own learning curves that I'm still working on, and they are not as finicky as a knife blade. Are 1/4 round/head knives easier? I saw Jo on JH Leather use one, it didn't look as scary as a head knife.
I will try to watch some Armitage videos. Sometimes I like watching videos, other times it is hard for me to sit still (depends if my meds have worn off or not).
Did you hammer your stitches flat once you were done? That can help the overall presentation of your stitching lines too.
Keep going, learn from each piece and improve as you go - but these that you’ve made are lovely gifts.
Have you tried a Fiskars rotary knife?  They don't drag or stretch the leather.
Are you pulling your threads through in a consistent way.
Supporting the project in a sewing clamp; When I sew, as the thread from the right side goes though the hole to the left side I pull the thread back towards my body, and the thread going from right to left is fed through the hole on the side away from my body and is then pulled tight away from my body. Then this right-left thread becomes right to left on the next hole
Try a single head knife a lot less daunting than a double head knife/round knife spend a day cutting shapes out of scrap leather also pratice skiving with it just remember to keep you're free hand behind the cutting edge, it is the right tool for the job. Be mindful of some of of the videos on youtube of people using a round knife, have to say some frighten me watching them. There is another knife that might be easier for you working with lighter weight of leather  its called a clicker knife but it is a a pull cut type of knife.
single head head knife
https://www.georgebarnsleyandsons.co.uk/product-page/saddlers-head-knife
clicker knife the curved blade, good for tight corners.
https://www.georgebarnsleyandsons.co.uk/product-page/extension-clicker-handle
Hope this helps
JCUK
I watched the Armitage video and I think I know how to do it correctly now. But I also have a choice - I can make the stitching line a "proper" zig-zag, or I can do a straight line, which is probably what most laypersons think of as "regular/proper" stitching. When you make stuff for other people, do they like the zig-zag or are they all "why is your stitching slanted"? Because I'm thinking maybe I will purposefully make the stitching line flat/linear so it looks "normal."
1 hour ago, Alaisiagae said:
. . . But I also have a choice - I can make the stitching line a "proper" zig-zag, or I can do a straight line, which is probably what most laypersons think of as "regular/proper" stitching. When you make stuff for other people, do they like the zig-zag or are they all "why is your stitching slanted"? Because I'm thinking maybe I will purposefully make the stitching line flat/linear so it looks "normal."
Actually, my customers/clients don't care a sausage. As long as the sewing is neat and fairly consistent
