Members eatbeef88 Posted November 3, 2020 Members Report Posted November 3, 2020 I am looking for advice on edging inside corners of a project. I can get witching about 1/8-1/4” from the corner with my edger but not all the way in to the corner. Thanks in advance for the insight. Quote
Contributing Member fredk Posted November 3, 2020 Contributing Member Report Posted November 3, 2020 Do you mean bevelling the edge? To get into the corner I use a no.11 scalpel blade very carefully, or even a razor blade held in my fingers, just whichever is laying handy on the work bench Quote
Members Rahere Posted November 3, 2020 Members Report Posted November 3, 2020 An awl used as an impresser also works, as long as you use the tip drawing away from the crease lines, never forwards so it pierces. Quote
Members Dwight Posted November 3, 2020 Members Report Posted November 3, 2020 9 hours ago, eatbeef88 said: I am looking for advice on edging inside corners of a project. I can get witching about 1/8-1/4” from the corner with my edger but not all the way in to the corner. Thanks in advance for the insight. First thing . . . can you post a picture of an example of your problem . . . Secondly . . . I use those cheap Tandy bevelers . . . and never have a problem . . . So I think there is probably something I don't quite grasp . . . in your post. May God bless, Dwight Quote
Members eatbeef88 Posted November 5, 2020 Author Members Report Posted November 5, 2020 On 11/3/2020 at 6:56 AM, Dwight said: First thing . . . can you post a picture of an example of your problem . . . Secondly . . . I use those cheap Tandy bevelers . . . and never have a problem . . . So I think there is probably something I don't quite grasp . . . in your post. May God bless, Dwight Thanks for the reply Dwight. As you can see in the picture, I can use my edger to get within about 1/4” of the corner but can get in there all the way. Quote
Members eatbeef88 Posted November 5, 2020 Author Members Report Posted November 5, 2020 On 11/2/2020 at 9:58 PM, fredk said: Do you mean bevelling the edge? To get into the corner I use a no.11 scalpel blade very carefully, or even a razor blade held in my fingers, just whichever is laying handy on the work bench Attached is a picture of what I’m talking about. I am able to get within about 1/4” of the corner with my edger but can’t get all the way in to the corner. Quote
Members Dwight Posted November 5, 2020 Members Report Posted November 5, 2020 I am not sure why you cut a square corner in your project . . . But unless it is absolutely necessary . . . it is almost a cardinal sin in leather work to do that. Make a rounded cut . . . it makes all the world of difference as to your ability to edge the item. This is my carry holster . . . as you can see there are two really close rounded cuts Those cuts are made with a punch . . . then I come out from circle on each side with a razor knife to make the opening. Later I go in on both sides with a edging tool . . . gets it completely and no problems that are not solved when I burnish the edge. May God bless, Dwight Quote
Members paloma Posted November 5, 2020 Members Report Posted November 5, 2020 (edited) to have beautiful interior corners I put a punch before cutting, it's easier then to sand it with a piece of sandpaper on a round support. and then I smooth it with a burnisher after having moistened the leather and passed a little glycerin soap. Edited November 5, 2020 by paloma Quote
CFM Hardrada Posted November 6, 2020 CFM Report Posted November 6, 2020 Sometimes folding the leather in two along the axis of the corner will expose enough of it to allow you to run the edger over it. Quote
Members jcuk Posted November 6, 2020 Members Report Posted November 6, 2020 Start just before the right angle of the area you want to edge, holding the edge shave steeply it will take you round the angle then level off only edge to of the centre of that area. Stop, turn your work around - do the same from the opposite angle edge shave up to where you you have already edge shaved to, (it will feel a cack handed so may take some practice on some scrap leather at first to get comfortable with even now if i have done it for a while still feels odd. Being left handed some my tools are for for right handed people so i get used to using tools feeling cack handed). Hope this helps JCUK Quote
