Members Wintersunset Posted November 23, 2020 Members Report Posted November 23, 2020 What is the difference between Adler 105-64 and Adler 169? I make horse tack so I use heavy harness leather, often combined with thick soft foam covered with soft lambskin as a padding. I'm looking for a machine that can handle these two materials combined. Thank you! Quote
Moderator Wizcrafts Posted November 23, 2020 Moderator Report Posted November 23, 2020 The Adler 105-64 was a heavy duty needle feed stitcher than is heavier duty than the 69.169/269 models. It is able to sew 7/16 inch with up to #346 thread. Any more thickness may not feed or sew properly. The 69/169 have triple feed but are lighter duty and can't sew as thick, nor use thread heavier than about #138. Both are long out of production. I use a Cowboy CB4500 for harness, holster and saddle work. It sews over 3/4 inch and has triple feed. Quote
Members Constabulary Posted November 23, 2020 Members Report Posted November 23, 2020 (edited) The 105-64 is the heavier machine and has a larger hook, and can handle thicker threads & needles Its it a drop feed + needle feed machine. Here are some Data: Edited November 23, 2020 by Constabulary Quote
Members miker Posted January 20, 2021 Members Report Posted January 20, 2021 What are the differences between Adler 69 and 169? Is 169 heavier duty than 69? Quote
Uwe Posted January 21, 2021 Report Posted January 21, 2021 (edited) Mainly the Adler 69 and 169 have very different arm and hook designs, each with its own merits and shortcomings. Both are light/medium duty machines. Relative merits of thin vs. thick arms, and horizontal vs. vertical axis hooks have been discussed in multiple topics previously. This question really belongs in a new/separate topic, as this particular topic is about Adler 105 vs.169. Edited January 21, 2021 by Uwe Quote
Members miker Posted January 21, 2021 Members Report Posted January 21, 2021 i just didn't want to add one more topic! I am using a 69 but i a friend is selling a 169 for something like 200euros! Very low price and i am thinking to get it! It's an old machine but i believe i can refubrish it! Quote
Members Matt S Posted January 21, 2021 Members Report Posted January 21, 2021 4 minutes ago, miker said: i just didn't want to add one more topic! I am using a 69 but i a friend is selling a 169 for something like 200euros! Very low price and i am thinking to get it! It's an old machine but i believe i can refubrish it! Keeping different topics/conversations in different threads helps with archiving and searching. New threads for new conversations won't clog the servers up but it might help the next 10 people with a similar question to find the discussion and get their answer! €200 for an Adler 169 sounds like a bargain, depending on condition. A similar quality equivalent machine from a premium manufacturer will be at least €3000, but you may spend several times more than €200 on parts and labour bringing it up to a level where you're happy to use it. €200 is about the price of a new Japanese made hook or basic servo motor, so if it's basically fine but has a damaged hook and an old fashioned clutch motor (like a lot of old machines will be) you'll triple the price before even putting thread to leather. A 169 won't do much that a 69 can't, and it can't get into tight spots like a 69 can, but it might be worth it to have a backup machine, or to have each machine set up for specific jobs. Quote
